Find the center of the circle of curvature
In summary, the equation of the line is y-1=-0.5(x-1), and it goes through the point (1,1). The distance formula says r=\frac { 25 }{ 2\sqrt { 5 } } =\sqrt { { (1-{ x }_{ 0 }) }^{ 2 }+{ (1-y_{ 0 }) }^{ 2 } }, but there's an x and a y.
Sho Kano
372
For the curve with equation [itex]y={ x }^{ 2 }[/itex] at the point (1, 1) find the curvature, the radius of curvature, the equation of the normal line, the center of the circle of curvature, and the circle of curvature.
[itex]\kappa \left( 1 \right) =\frac { 2\sqrt { 5 } }{ 25 } \\ r=\frac { 1 }{ \kappa } =\frac { 25 }{ 2\sqrt { 5 } } \\ y-1=\frac { -1 }{ 2 } \left( x-1 \right) [/itex] I have no idea how to find the center, I've tried the distance formula, and even a vector approach
The centre of the radius of curvature must be on the line that is perpendicular to the tangent to the curve at (1,1), the equation of which you can calculate. Having done that, what info do you already have that tells you how far along that line the centre of curvature is?
Well, I have the line which goes straight through the center, and I also have the radius (how far I should go), but need an x and a y value
What is the equation of the line?
Does it go through (1,1)?
What are the coordinates of the point on that line that is distance r from (1,1), in the direction towards the inside of the curve?
The equation of the line is [itex]y-1=-0.5(x-1)[/itex], and it goes through the point (1,1). The distance formula says [itex]r=\frac { 25 }{ 2\sqrt { 5 } } =\sqrt { { (1-{ x }_{ 0 }) }^{ 2 }+{ (1-y_{ 0 }) }^{ 2 } } [/itex], but there's an x and a y.
You have two equations, and two unknowns ##x_0## and ##y_0##.
Got it, it's (x+4)^2 + (y-7/2)^2 = 125/4.
Thanks
Related to Find the center of the circle of curvature
1. What is the center of curvature?
The center of curvature is the point on the circle that has the same curvature as a given point on a curve.
2. How is the center of curvature calculated?
The center of curvature can be calculated by finding the perpendicular bisector of the tangent line at a given point on a curve. The intersection of this perpendicular bisector with the normal line passing through the given point will give the center of curvature.
3. What is the significance of finding the center of curvature?
Finding the center of curvature is important in understanding the behavior of curves. It helps in determining the radius of curvature at a given point, which is crucial in many applications such as designing roads or analyzing the motion of objects.
4. Can the center of curvature be located at any point on a curve?
No, the center of curvature can only be located at points where the curve is changing direction, such as at the point of inflection or at a sharp turn. At a straight section of a curve, the center of curvature is located at infinity.
5. How is the center of curvature related to the radius of curvature?
The center of curvature and the radius of curvature are closely related. The radius of curvature is the distance between the center of curvature and a given point on a curve. As the curve changes direction, the radius of curvature also changes, but the center of curvature remains constant.
  • Differential Geometry
