Find the centre of mass for this sheet of paper with a cutout
In summary, to find the center of mass of a uniform, rectangular sheet with a punched hole, you can consider the system as the big rectangle and the small rectangle, but with negative mass. The center of mass of a symmetric shape is on all symmetry axes, so the center of mass of the rectangle is in the middle. To find the center of mass, you can use the formula XCM=(x1m1+x2m2)/(m1+m2) with the positions and masses of both rectangles.
mrmerchant786
A uniform, rectangular sheet with sides of lengths a and b has a hole of dimensions a/4 by b/4 punched in it as shown below. Find the centre of mass of the sheet after the hole is made.
CM= ∫xdm/∫dm
I'm confused on what to input into the above equaiton
I do know that it will like on the axis of symetry so on the line y=b/2
many thanks :)
CM= ∫xdm/∫dm
many thanks :)
You can consider the system as the big rectangle and the small rectangle, but with negative mass.
thanks for the reply, so would the answer be
CM= ∫xthe whole sheetdmthe whole sheet/∫dmthe whole sheet - ∫xthe cut out dmthe cut out/∫dm the cut out
No, it is not simply the difference between the CM-s.
Supposing you have two small balls at x1 and x2, of masses m1 and m2, how do you get the common center of mass?
And no need to integrate, the CM of a rectangle is in the centre.
hmm to answer your question x1*m1 + x2*m2 / m1 + m2 ?
in regards to my question so would it be the centre coordinates minus a (xcentre of cut out*ρ*area of cut out)/(ρ*area of cut out)
Do not forget the parentheses. Xcm=(x1*m1 + x2*m2) / (m1 + m2 )
No.
No.
okay then, what would it be then?
Choose a system of coordinates, for example, that in the picture. Point P is the CM of the big rectangle, Q is the CM of the small one.
You can consider the mass of a rectangle compressed in the CM.
If the density and thickness of the plate is homogeneous, the mass is proportional to the area. The CM of a symmetric shape is on alll symmetry axis, in case of the rectangle, it is on the middle.
What are the positions of the CM-s of both rectangles?
What are the masses (areas)?
Then apply the formula XCM =(x1m1+x2m2)/(m1+m2) for the masses at P and Q. ( consider m2 negative)
Related to Find the centre of mass for this sheet of paper with a cutout
1. What is the concept of centre of mass?
The centre of mass is a point on an object where the weight of the object can be considered concentrated. It is the point at which an object would balance if it were placed on a single support.
2. How is the centre of mass calculated for an object?
The centre of mass is calculated by finding the weighted average of the positions of all the particles that make up the object. This means taking into account the mass and distance of each particle from a reference point.
3. How does the presence of a cutout affect the centre of mass for a sheet of paper?
The presence of a cutout affects the centre of mass by shifting it away from the cutout. This is because the cutout reduces the mass of the paper in that area, causing the centre of mass to move towards the heavier regions.
4. Can the centre of mass be located outside of the physical boundaries of an object?
Yes, the centre of mass can be located outside of the physical boundaries of an object. This can occur when the object has an irregular shape or when there is a cutout present, causing the centre of mass to shift towards the heavier regions.
5. Why is finding the centre of mass important in science?
Finding the centre of mass is important in science because it allows us to understand the balance and stability of objects. It is also used to calculate the motion and equilibrium of objects, and is a crucial concept in fields such as physics and engineering.
13K
