Find the change in entropy for an ideal gas undergoing a reversible process
The discussion focuses on calculating the change in entropy for an ideal gas during a reversible process. The initial approach uses the first law of thermodynamics and integrates expressions for internal energy and pressure. Corrections are suggested, emphasizing the need for a general expression for internal energy that accounts for the number of moles and molar heat capacity. The participants confirm the importance of including the factor of the number of moles in the calculations. Overall, the conversation highlights the complexities of thermodynamic calculations and encourages further practice.
mcas
An ideal gad had a temperature ##T_1## and volume ##V_1##. As a result of a reversible process, these quantities changed to ##T_2## and ##V_2##. Find the change in entropy.
##pV=nRT##
##\delta Q = TdS##
##dU = \delta Q + \delta W##
##U = \frac{3}{2}kT##
We know that
$$dU=\delta Q + \delta W$$
$$dU = TdS - pdV$$
So from this:
$$dS = \frac{1}{T}dU + \frac{1}{T}pdV \ (*)$$
For an ideal gas:
$$dU = \frac{3}{2}nkdT$$
Plugging that into (*) and also from ##p=\frac{nRT}{V}## we get:
$$S = \frac{3}{2}nk \int^{T_2}_{T_1} \frac{1}{T}dT + R\int^{V_2}_{V_1} \frac{1}{V}dV$$
And so on...
Is this the correct approach to solve this problem? I'm not really sure because I'm still new to thermodynamics.
Your approach looks good. A couple of things, though.
This equation is for a monatomic ideal gas and it's missing a factor of ##N## (the number of molecules). But the question does not specify that the gas is monatomic. So, you'll need a more general expression for ##U## (usually expressed in terms of the number of moles ##n##, the molar heat capacity at constant volume, ##C_V##, and ##T##).
The first term should be corrected according to the remarks above. The second term is missing a factor. Can you spot it?
Likes etotheipi and mcas
Ok, thank you. I think I know which one :smile:
I missed ##n##, right?
Thank you, this means very much! Now I have the motivation to do more problems 😁
Likes etotheipi and TSny
Yes.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
