Find the charge of the oil drop
In summary, the charge of the oil drop is the amount of electric charge present on the surface of an oil droplet, measured in coulombs. It is determined using the oil drop experiment by suspending a droplet in an electric field and calculating the charge based on the strength of the field and the mass of the droplet. Factors such as type of oil, humidity, temperature, impurities, field strength, and droplet size can affect the charge. This experiment has real-world applications in the development and testing of electronic components and the study of atmospheric electricity. It also contributed to the understanding of electric charge and the atomic theory of matter through its first use by Robert Millikan in 1909.
Fatima Hasan
319
E = σ / 2ε
E = Fel / Q
E = σ / 2ε
= 17.7*10-9 /(2*8.85*10-12)
E =1000 N/C
ΣF = 0
Fel + mg = 0
Fel = - mg
1000 * q = - 10-3
q = - 10-3 / 1000 = 10-6 C
= -1μC
Could somebody check my answer please ?
If the charge of the drop is negative, is the direction of the electric force towards or away from the plate? What about the direction of gravity, towards or away?
Likes Fatima Hasan
Which way is positive ? Then think about the sign of ##g##
Related to Find the charge of the oil drop
What is the charge of the oil drop?
The charge of the oil drop refers to the amount of electric charge present on the surface of an oil droplet. This charge can be either positive or negative and is typically measured in units of coulombs.
How is the charge of the oil drop determined?
The charge of an oil drop can be determined using an experiment known as the oil drop experiment. This involves suspending a droplet of oil in an electric field and measuring the force acting on the droplet. By knowing the strength of the electric field and the mass of the droplet, the charge of the oil drop can be calculated.
What factors can affect the charge of the oil drop?
The charge of an oil drop can be affected by a number of factors, including the type of oil used, the humidity and temperature of the surrounding environment, and the presence of any impurities on the surface of the droplet. Additionally, the strength of the electric field and the size of the droplet can also impact the charge.
Why is finding the charge of the oil drop important?
Finding the charge of the oil drop is important in understanding the nature of electric charge and its behavior. This experiment, first conducted by Robert Millikan in 1909, helped to determine the fundamental unit of charge and contributed to the development of the atomic theory of matter.
Are there any real-world applications for knowing the charge of the oil drop?
Yes, there are several real-world applications for knowing the charge of the oil drop. For example, this experiment is used in the development and testing of electronic components, such as transistors and capacitors. It is also used in the study of atmospheric electricity and the formation of thunderstorms.
