Eshka
- 2
- Homework Statement
- there is a spring weighing 0.2 kilograms. when not stretched, its length is 67 millimeters, and when stretched 1200 millimeters, and the spring stretches down only under its own weight, without additional load. Calculate the spring stiffness coefficient.
- Relevant Equations
- F = k * x maybe
So, I tried to solve this problem as follows. if the spring is stretched without load, then it is stretched by its own weight, therefore, by gravity. therefore, I decided that the elastic force is equal to gravity, but this is not the case, the teacher said that this is incorrect. Then I assume that the spring stretches unevenly (probably), that is, if it stretches under its own weight, there will be almost no tension at the beginning, and at the bottom it will stretch more. So you need to divide it into many separate sections and calculate (PROBABLY), but I don't understand what formula to use for this and if this assumption is incorrect, then I can't solve the problem at all.
