Find the components of the vector by rotating the origin
In summary: (a)+\sin(b)##, one can find ##\vec{e}_x' = \vec{e}_x + \vec{e}_\alpha, \vec{e}_y'= \vec{e}_y + \vec{e}_\alpha##.
Jtechguy21
51
Hello, I just started my summer class "Applied Linear Algebra I"
Last math class of my under-grad and its been 1 year since I've last taken Calc3, so I'm trying my best to get back into the groove...anyways.
Our first topic we are discussing in class is vectors.
[1]
This is all the information give to me.
Consider the Vector v = [x y] or <x, y > (which ever notation you prefer)
Find the components of the vector obtained by rotating v about the origin counter clockwise through an angle of 30 degrees.
Vector v lives in Quadrant 1, and therefore all I know is that x, and y are positive.
So I rotate vector v by 30 degrees counter clock wise.
(Attached rough sketch)
I'm not sure what to do next but this is what I believe.
cos 30 = (square root of (3) )/ 2
sin 30 = 1/2
cos 30 = x / 1 (CAH)
sin 30 = y /1 (SOH)
Answer 1]
Components of vector v = <x,y>
Answer 2]
Components of vector v = < cos30, sin30 >
Can someone please tell me if I am on the right track.
thanks any guidance towards the right direction is greatly appreciated. I am here to learn.
[1]
sin 30 = 1/2
sin 30 = y /1 (SOH)
Answer 1]
Answer 2]
You haven't rotated the vector <x,y> by 30 degrees, you've rotated the vector <1,0> by 30 degrees. Don't you have a formula for rotating a vector by an angle somewhere in your book or notes?
[1]
sin 30 = 1/2
sin 30 = y /1 (SOH)
Answer 1]
Answer 2]
Figure out the new vectors ##\vec{e}_x', \, \vec{e}_y'\,##, obtained by rotating the vectors ##\vec{e}_x = \langle 1,0 \rangle## and ##\vec{e}_y = \langle 0,1 \rangle## through 30 degrees. Now use that facts that ##\vec{v} = \langle x,y \rangle = x \vec{e}_x + y \vec{e}_y## and the rotation operation is linear.
Basically, this method replaces geometry by algebra!
Jtechguy21 said:
This is the figure you posted. It doesn't correspond to the exercise that you're trying to complete. See Dick's response.
Rotation can be thought of as an operator, and thus represented by a matrix.
If your trig is better than your linear algebra, you could also do the following:
If you start with polar coordinates, ## x = rcos \theta, y = r sin \theta ## then the image after rotation by ##\alpha ## is ##x'= r cos (\theta + \alpha), y' = r sin(\theta + \alpha) .##
Using sum angle formulae ## \sin(a+b) = \sin a \cos b + \cos a \sin b, \cos(a+b) = \cos a \cos b - \sin a \sin b,## you get
## x' = r \cos \theta \cos \alpha - r \sin \theta \sin \alpha, y' =r \sin \theta \cos \alpha + r\cos \theta \sin \alpha##
Substitute back in your original x and y to get x' and y' in terms of x, y, and alpha.
Now, build a matrix ##M(\alpha)## to multiply ##\pmatrix{x\\y}## by, such that ##M(\alpha)\pmatrix{x\\y} =\pmatrix{x'\\y'} ##, and you will have the general form for any rotation (counterclockwise).
I see what you're saying.
I've only had one class session so far, and for the first week he is teaching out of the book...
So I am using google and here for learning this for now.
Where did <1,0> and <0,1> come from?
is it because since we are in R2. X, and Y are standard basis vectors
therefore x = <1,0> and y = <0,1>
So that means when I graph it i graph the x and y vector correct?
and the next to step it to rotate it by 30 degrees counter clock wise?
You had them in that figure you included. They don't actually belong in this problem.
Okay thanks for pointing that out. I just picked random position in Quadrant I since I wasn't given the x or y coordinates of vector v.
You can't just pick the magnitude of the vector to be 1 .
I don't think I did, in my mind this is the steps i did.
I picked a random x, y position for vector v.(in quad 1)
then rotated it by 30 degrees counter clock wise.
Formed a right triangle(30,60,90), and made the hypotenuse 1, so i can attempt to solve for x and y.
I have a very similar example in my notes,
however in my example, it actually has a numerical value for the two components. such as vector m = <1,0>
Making the hypotenuse equal to 1 is the same as making the magnitude of the vector equal to 1 .
True, I just thought about it You are right.
What would be the first step you suggest to take to begin solving this problem?
Ray was implying that if you know how to transform the basis vectors, you can make the general form for the operation.
For example, a rotation by 90 degrees takes (1,0) to (0,1) and (0,1) to (-1,0).
Stacking the resulting vectors into a matrix ##\pmatrix{ 0, -1\\ 1, 0 } ## gives a matrix operation that does the job.
(edited matrix format)
You can verify this by doing the operation:
##\pmatrix{ 0, -1\\ 1, 0 }\pmatrix{ 1\\0 } =\pmatrix{ 0\\1 }, \pmatrix{ 0, -1\\ 1, 0 }\pmatrix{ 0\\1 } = \pmatrix{ -1\\0 }.##
In general, this is true for any (x,y) so:
##\pmatrix{ 0, -1\\ 1, 0 }\pmatrix{ x\\y } =\pmatrix{ -y\\x } . ##
Is the form for rotation by 90 degrees.
thanks for explaining that to me, it makes better sense.How do i approach this problem since I don't know what x or y is in vector v?
*edited to show correct order for basis vectors*
So what does the rotation of (1,0) look like? Call that (a,b)
How about the rotation of (0,1)? Call that (c,d)
Make a matrix ##\pmatrix{ a, c \\ b, d } ##.
Multiply ##\pmatrix{ a, c \\ b, d }\pmatrix{ x \\ y } ##.
Boom! You're done.
RUber said:
So what does the rotation of (0,1) look like? Call that (a,b)
How about the rotation of (1,0)? Call that (c,d)
Boom! You're done.
This is for a rotation of 90° .
Boom! You're done.
Looks easy enough, I understand the intuition behind your answer, and why you chose arbitrary variables to represent the position it rotated to.
But my main concern is where did (0,1) and (1,0) come from?
x = (0,1)
and y =(1,0) ?
As you suggested earlier, this is due to the standard basis used for (x, y) .
Oops, your basis should be in the right order, so (1,0) should go first, then (0,1) to make the right operation for (x,y).
You could also look at my post #5 for some hints for the trig without using the basis vector method. The resulting matrix operation is the same either way.
yeah that's what i meant to write. thanks for being patient with me and explaining it to me.
Im using all my free time to study for my linear class(first time taking it), because i want to do very well in it since its 8 week course instead of 16.
I saw your post about the trig way , looks interesting, and honestly i will probably use your method for curiosity with a more concrete example to wrap my mind around it better.
FAQ: Find the components of the vector by rotating the origin
1. What is the process for finding the components of a vector by rotating the origin?
The process for finding the components of a vector by rotating the origin involves using trigonometric functions and basic geometry. First, determine the magnitude and direction of the original vector. Then, use the angle of rotation to create a right triangle. The x-component of the new vector is found by multiplying the magnitude of the original vector by the cosine of the angle of rotation. Similarly, the y-component is found by multiplying the magnitude by the sine of the angle of rotation.
2. What is the purpose of finding the components of a vector by rotating the origin?
The purpose of finding the components of a vector by rotating the origin is to break down a vector into its horizontal and vertical components. This can be useful in various applications, such as calculating the force and direction of an object moving along a curved path, or finding the net force acting on an object when multiple forces are acting on it.
3. How do you determine the direction of the components when rotating the origin?
The direction of the components can be determined by the angle of rotation. If the angle of rotation is measured counterclockwise from the positive x-axis, the x-component will be in the same direction as the original vector, while the y-component will be perpendicular to it. If the angle of rotation is measured clockwise from the positive x-axis, the x-component will be in the opposite direction of the original vector, while the y-component will be perpendicular to it.
4. Can the components of a vector be negative when rotating the origin?
Yes, the components of a vector can be negative when rotating the origin. This is because the direction of the components is determined by the angle of rotation, which can be positive or negative depending on the direction of rotation. A negative angle will result in negative components, while a positive angle will result in positive components.
5. How does the order of the components change when rotating the origin?
The order of the components does not change when rotating the origin. The x-component will always be listed first, followed by the y-component. However, the signs of the components may change depending on the direction of rotation, as mentioned in the previous question.
