Find the compositions of these functions?
  • Thread starter thereddevils
  • Tags
    Functions
In summary, the conversation discusses finding the composition of two functions, f(x)=x^2+3 and g(x)=|x|-5, and determining the ranges and domains of the resulting function gf(x). It is concluded that the range of g(x) is [-5, infinity) while the range of gf(x) is [-2, infinity). The discussion also mentions that the domains of f(x) and gf(x) are the same.
thereddevils
438
Given two functions , f(x)=x^2+3 , where x is real , g(x)=|x|-5 , x is real , find gf(x).
i found gf(x)=x^2-2
is it true that the range of gf(x) is the same as the range of g(x) ? If so,
the range of g(x) is [-5 , infinity) and the range of gf(x) is [-2 , infinity)
why arent they the same ?
I think everything is correct, why would you think the range of g(f(x)) is the same as the range of g(x)?
I'll pose the reverse question: why should they be the same? g(x) and gf(x) are different functions.
Take a look at the diagram i attached . Isn't that the image of gf(x) the same as the image function g(x) ?
The range of [itex]f[/itex] needn't be the whole of the domain of [itex]g[/itex] so some of the images under [itex]g[/itex] may not occur in [itex]gf[/itex]. You only have [itex]range(gf)\subseteq range(g)[/itex]. In fact you could say they're not equal because you have yourself provided a counterexample.
thanks Martin , how about the domains , is the domain of f(x) the same as domain gf(x) because both of them started from the same set or it needn't also be the same in this case.
Yes, [itex]dom(gf)=dom(f)[/itex], assuming you only define the composition [itex]gf[/itex] when [itex]range(f)\subseteq dom(g)[/itex].
thanks again Martin !
FAQ: Find the compositions of these functions?
What is the purpose of finding the compositions of functions?
The purpose of finding the compositions of functions is to understand how two or more functions interact and how their outputs can be combined to create a new function. This can be useful in solving mathematical problems and analyzing real-world systems.
How do you find the composition of two functions?
To find the composition of two functions, you must first evaluate the inner function using the input from the outer function. The resulting output becomes the input for the outer function. This process can be repeated for multiple functions.
What is the difference between composition of functions and multiplication of functions?
The composition of functions involves using the output of one function as the input for another function, while multiplication of functions involves multiplying the outputs of two functions. In other words, composition combines functions, while multiplication multiplies them.
Can any two functions be composed?
Not all functions can be composed. For two functions to be composed, the output of the inner function must be a valid input for the outer function. In other words, the domain of the inner function must be a subset of the domain of the outer function.
How can I use the composition of functions in real life?
The composition of functions can be used to model real-world systems, such as financial investments, population growth, and chemical reactions. It can also be used to solve optimization problems and analyze the behavior of complex systems.
