Find the condition for equality to hold
  • MHB
  • Thread starter anemone
  • Tags
    Condition
In summary, the conversation discusses a problem where the equality $x^2+y^2=1$ needs to be proven, given the equation $x\sqrt{1-y^2}+y\sqrt{1-x^2}=1$. The speaker suggests using the Cauchy-Schwarz inequality, which shows that the left side of the equation is less than or equal to 1. They then try to work backwards and deduce the condition from the inequality, ultimately arriving at the conclusion that $x^2+y^2=1$.
anemone
MHB
POTW Director
3,883
115
Hi,
I've encountered a problem in deciding the condition in order for the equality to hold.
Here is the problem:
If $x\sqrt {1-y^2} + y \sqrt {1-x^2}=1$, prove that $x^2+y^2=1$
By using the Cauchy-Schwarz inequality, it's fairly easy to prove that $x\sqrt {1-y^2} + y \sqrt {1-x^2}\leq1$
Next, what I tried to do is to work backwards and let $x^2+y^2=1$, then I see that $x=\sqrt {1-y^2}$. After making that substitution into the LHS of the inequality $ x\sqrt {1-y^2} + y \sqrt {1-x^2} $ and I eventually get 1 as the final answer.
What do you think, Sir? I feel bad for doing this.
Do you have any idea to deduce the condition from $x\sqrt {1-y^2} + y \sqrt {1-x^2}\leq1$?
Thanks.
Mathematics news on Phys.org
anemone said:
Hi,
In the Cauchy Schwarz inequality, equality holds only if
$\displaystyle \frac{x}{\sqrt{1-x^2}}=\frac{\sqrt{1-y^2}}{y}$
$\displaystyle xy=\sqrt{(1-x^2)(1-y^2)}$
$\displaystyle x^2y^2=(1-x^2)(1-y^2)=1-x^2-y^2+x^2y^2$
$\displaystyle x^2+y^2=1$
Gosh, I missed that part of definition!:eek:
Thanks, Alexmahone.
FAQ: Find the condition for equality to hold
What is the meaning of "Find the condition for equality to hold"?
When we talk about finding the condition for equality to hold, we are referring to the mathematical concept of determining the values of variables or conditions that make an equation or inequality true.
Why is it important to find the condition for equality to hold?
Knowing the condition for equality to hold is crucial in solving equations and inequalities, as it allows us to find the specific values that make them true. This helps us in making accurate calculations and drawing conclusions from mathematical equations.
What are the different methods used to find the condition for equality to hold?
There are various techniques that can be used to find the condition for equality to hold, such as substitution, elimination, and graphing. These methods involve manipulating equations and inequalities to isolate the variable and determine its value.
Can the condition for equality to hold be different for different equations or inequalities?
Yes, the condition for equality to hold can vary depending on the equation or inequality being solved. Each equation or inequality has its own unique set of conditions that make it true, and it is important to identify these conditions in order to find the solution.
How can I check if my solution satisfies the condition for equality to hold?
To check if a solution satisfies the condition for equality to hold, simply plug in the values of the variables into the original equation or inequality and see if it makes the statement true. If it does, then the solution is correct. If not, then you may need to re-evaluate your solution.
