MHB Find the Conjugate of a Denominator with Radicals
  • Thread starter Thread starter bergausstein
    Radicals
The discussion focuses on finding the proper conjugate of the denominator in the expression (2 + √3 - √5). Participants clarify that the conjugate should be multiplied with respect to the terms involving radicals. The correct approach involves multiplying the denominator by its conjugate, resulting in a simplified expression. It is emphasized that while rationalizing the denominator, the numerator's form is generally left unchanged unless specified otherwise. The conversation concludes with a method to achieve the desired rationalization effectively.
bergausstein
can you tell me what is the proper conjugate of the denominator.
what is the rule on how to group this kind of denominator to get the conjugate.$\displaystyle \frac{2+\sqrt{3}+\sqrt{5}}{2+\sqrt{3}-\sqrt{5}}$
thanks!
Mathematics news on Phys.org
I'd first multiply by the conjugate with respect to $\sqrt{5}$ and then multiply by the conjugate with respect to $\sqrt{3}$.
what do you mean by "with resperct to $\sqrt{5}$ and $\sqrt{3}$?
First multiply the denominator by $2 + \sqrt{3} + \sqrt{5}$ to get $\left (2 + \sqrt{3}\right )^2 - 5 = 2 + 4\sqrt{3}$ and then multiply by $2 - 4\sqrt{3}$
my answer is
$\displaystyle \sqrt{3}+\frac{2\sqrt{5}}{11}+\frac{3\sqrt{15}}{22}$
is this correct?
No. Can you check your calculations?
Don't forget you also need to multiply the numerator
$$\dfrac{2+\sqrt3+\sqrt5}{2+\sqrt3-\sqrt5}$$
$$\dfrac{2+\sqrt3+\sqrt5}{(2+\sqrt3)-\sqrt5} \times \dfrac{2+\sqrt3+\sqrt5}{(2+\sqrt3)+\sqrt5}$$
$$=\dfrac{(2+\sqrt3+\sqrt5)^2}{(2+\sqrt3)^2-5}$$
I would now expand $$(2+\sqrt3)^2$$ to get [math]7 + 4\sqrt(3)$$
If you put that in the fraction and collect like terms (ie: 7-5=2):
$$=\dfrac{(2+\sqrt3+\sqrt5)^2}{2+4\sqrt3}$$
Are you aware of the conjugate in this last expression? Generally when you rationalise the denominator nobody cares about the numerator - unless explicitly told otherwise leave it as is
You can also do it "the other way":
$\dfrac{2+\sqrt{3}+\sqrt{5}}{2+\sqrt{3}-\sqrt{5}}$
$= \dfrac{2+\sqrt{3}+\sqrt{5}}{2+\sqrt{3}-\sqrt{5}}\cdot\dfrac{2-(\sqrt{3}-\sqrt{5})}{2-(\sqrt{3}-\sqrt{5})}$
$=\dfrac{6+4\sqrt{5}}{4 - (\sqrt{3} - \sqrt{5})^2}$
$=\dfrac{6+4\sqrt{5}}{4 - (8 - 2\sqrt{15})}$
$= \dfrac{6 + 4\sqrt{5}}{2\sqrt{15} - 4}$
At this point, you want to multiply by $2\sqrt{15} + 4$ top and bottom:
$= \dfrac{6 + 4\sqrt{5}}{2\sqrt{15} - 4}\cdot\dfrac{2\sqrt{15} + 4}{2\sqrt{15} + 4}$
whereupon you will arrive at an answer equivalent to SuperSonic4's (if you were to follow his next step).
  • · Replies 41 ·
  • · Replies 20 ·
