Find the correct value of the mean in the given problem
  • Thread starter Thread starter chwala
    Mean Value
chwala
See attached.
Statistics
Find the problem and solution below;
Now the part i do not seem to understand from the given solution is the negative value i.e to be specific ##-0.06##
In my understanding we shall have ##5## possibilities with each giving the correct mean value of ##3.48## which implies ##+0.06## from the given value on the text unless they meant ##3.48- 0.06=3.42##
They also did not indicate the correct value of the mean rather the difference.
My approach to the solution is as follows;
Consider the consecutive scores##1=12## and ##2=9## then it follows that the correct value of the mean will be given by;
##(171-30)+1(9)+2(12)=174##
##\dfrac{174}{50}=3.48##Consider the consecutive scores##2=12## and ##3=9## then it follows that the correct value of the mean will be given by;
##(171-51)+2(9)+3(12)=174##
##\dfrac{174}{50}=3.48##Consider the consecutive scores##3=12## and ##4=9## then it follows that the correct value of the mean will be given by;
##(171-72)+3(9)+4(12)=174##
Consider the consecutive scores##4=12## and ##5=9## then it follows that the correct value of the mean will be given by;
##(171-93)+4(9)+5(12)=174##
Consider the consecutive scores##5=12## and ##6=9## then it follows that the correct value of the mean will be given by;
##(171-114)+5(9)+6(12)=174##
Of course i would appreciate any other better approach. Cheers guys.
What if, e.g, it says 5=9 and 6=12 and then you had to swap them (so the opposite direction of your post)
You could have used a variable, n, in your method:
Suppose the incorrect calculation included Incorrect=12n + 9(n+1) = 21n+9. Then the correct calculation would be Correct=9n+12(n+1) = 21n+12. The difference (removing the Incorrect and adding the Correct) would be -(21n+9)+(21n+12) = 3. That would change the final mean of the 50 samples by 3/50 = 0.06.
Now suppose the opposite mistake was made. A similar calculation says that the difference would be -3, giving a change of -3/50=-0.06.
True, we shall have a mean value of ##3.36##Thanks.
@FactChecker smart move there...
