Find the D value of critical point and the type of critical point
In summary: This is not just a quirk of one variable calculus, but a real phenomenon that can occur in higher dimensions as well. In summary, the function f(x,y) = [e^(-y^2)]cos(4x) has a critical point at (0,0) and the task is to find the D value at this point and determine its type (max, min, saddle, or none). To find the D value, the partial derivatives (fx, fy, fxx, fyy, fxy, and fyx) must be computed. The correct values of these derivatives at (0,0) are fx = 0, fy = 1, fxx = -4, fyy = -4
coolusername
36
The function f(x,y) = [e^(-y^2)]cos(4x) has a critical point (0,0)
Find the D value at the critical point. What type of critical point is it? (max, min, saddle or none)
I know that to find the D value I must compute the partial derivatives (fox, fey, fxy and fyx)
fx = [-4e^(-y^2)]sin(4x)
fy = [-2ye^(-y^2)]cos(4x)
fxx = [-16e^(-y^2)](cos(4x)
fyy = [4(y^2)e^(-y^2)]cos(4x)
fxy = [8ye^(-y^2)]sin(4x)
D = (fxx)(fyy) - (fxy)^2
= [-16e^(-y^2)](cos(4x)[4(y^2)e^(-y^2)]cos(4x) - {[8ye^(-y^2)]sin(4x)}^2
evaluated at the critical point (0,0)
= (-16)(0) - (0)(0)
= 0
This means that the 2nd derivative test gave no info. But somehow it's not the right answer. Did I find the correct value of D? Is my approach correct?
Thanks
Having the discriminant be zero doesn't mean there is no max or min. In your case, ##f(0,0)=1##. Can you tell from the original equation whether that might be a max or min?
Likes 1 person
I see from the original equation that the max of f(x,y) is 1. However what would the value of D be? Did I calculate it correctly? I keep getting 0 but since the critical point has a max behaviour then shouldn't D be more than 0?
= (-16)(0) - (0)(0)
= 0
Thanks
Your second derivative ##f_{yy}## is incorrect; it should not be 0 at (0,0), and ##D(0,0) \neq 0##.
Likes 1 person
Oh, I forgot to do the product rule on fy thus my fyy was incorrect.
Thanks LCKurtz & Ray Vickson!
Regardless of the calculation error that I overlooked, the discriminant can be zero even though there is a relative max or min. This is even true in one variable. Consider ##y=x^4##. This has an absolute min at ##x=0## yet ##y'=0## and ##y''=0## at ##x=0## so the second derivative test fails to discriminate the relative min.
Related to Find the D value of critical point and the type of critical point
1. What is the D value of a critical point?
The D value of a critical point is the determinant of the Hessian matrix, which is a square matrix containing the second-order partial derivatives of a multivariable function. It is used to determine if a critical point is a maximum, minimum, or saddle point.
2. How do you find the D value of a critical point?
To find the D value of a critical point, you first need to calculate the Hessian matrix by taking the second-order partial derivatives of the function. Then, find the determinant of the matrix. If the determinant is positive, the critical point is a minimum. If it is negative, the critical point is a maximum. If it is zero, further analysis is needed to determine the type of critical point.
3. What is the significance of the D value in determining the type of critical point?
The D value is significant because it helps determine the nature of the critical point. If the D value is positive, the critical point is a minimum, which means the function decreases in all directions. If the D value is negative, the critical point is a maximum, and the function increases in all directions. If the D value is zero, further analysis is needed to determine the type of critical point.
4. What does a positive D value indicate about a critical point?
A positive D value indicates that the critical point is a minimum. This means that the function decreases in all directions around the critical point and has a lower value than all nearby points.
5. How does the type of critical point affect the behavior of a function?
The type of critical point affects the behavior of a function because it determines the direction in which the function changes around that point. A minimum critical point means the function decreases in all directions, while a maximum critical point means the function increases in all directions. A saddle point has both increasing and decreasing directions, making it a point of inflection for the function.
