Find the derivative of this function
In summary: So you now have two different ways to get the same derivative.Yes, that's what I meant. So you now have two different ways to get the same derivative.
Helly123
581
$$y = x.\log_e {\sqrt{x}}$$
f(x) = g(x) h(x)
f ' (x) = g ' (x) . h (x) - h ' (x) . g(x)
$$y = x .\log_e {\sqrt {x}}$$
$$y '(x) = 1.ln \sqrt{x} + \frac{1}{2} $$
the right answer is
$$ y ' = \log_{10} {\sqrt{x}} + \frac{1}{2} $$
$$ Is \ \log_e {\sqrt{x}} = \log_{10} {\sqrt{x}} \ ? $$
Second Try:
$$ y = x \log_e {\sqrt{x}} $$
$$ y = \log_e {x^{x/2}} $$
$$y ' = \frac{1}{x^{x/2}} . \frac{x}{2} . x^{(x-2)/2}$$
$$ y ' = \frac{1}{2}$$
why different result?
What is the derivative of ##\ln \sqrt{x}##?
Hint: Chain rule!
loge is the natural log. I don't know where they got log10.
In your second attempt, you cannot take derivative of xx or xx/2 like that.
If you use Wolframalpha and some other solvers, the natural log is often denoted by just log() with no subscript. Perhaps that's why you think it should be base 10? But your first attempt is not quite right.
Try your product rule again, taking care to not drop any factors of 1/2 along the way.
Likes Helly123
Also note that ##\log \sqrt{x} = \log x^{1/2} = \frac{1}{2}\log x##, regardless of the base of the logarithm.
That's definitely the simplest approach but perhaps the OP needs some practice with the chain rule.
Good point.
Hint: Chain rule!
derivative of ## \ln \sqrt{x} = \frac{1}{\sqrt{x}} . \frac{1}{2\sqrt{2}} ##
Show how you derived that. Where did the ##\sqrt{2}## come from? Did you mean that to be ##\sqrt{x}##?
Likes scottdave
derivative of ## ln \ u = \frac{1}{u} . \frac{d(u)}{d(x)} ##
derivative of ## \ln \sqrt{x} = \frac{1}{\sqrt{x}} . \frac{ d ( \sqrt{x} ) \ }{d(x)} ##
Hmm. Try ##\frac{ d ( \sqrt{x} ) \ }{dx}## again. Write it as ##\frac{ d ( x^{\frac{1}{2}}) \ }{dx}##.
Likes PeroK
##= \frac{1}{2}. x^{(\frac{1}{2} - 1)}##.
##\frac{1}{2}.\frac{1}{\sqrt{2}} ##
##x^{-\frac{1}{2}}## is not equal to ##\frac{1}{\sqrt{2}}##! Look at it carefully... You have to mean ##\frac{1}{\sqrt{x}}##. They aren't the same thing.
Likes Helly123 and PeroK
i'm sorry. yes I meant ##\frac{1}{\sqrt{x}}##.
Likes scottdave
derivative of ## \ln \sqrt{x} = \frac{1}{\sqrt{x}} . \frac{1}{2\sqrt{x}} ##
That's it. And that agrees with what you would get by differentiating ##\frac{1}{2} \ln{x}##, yes?
Do you see that the last expression can be simplified, and should be?
yes, thanks
derivative of ## \ln \sqrt{x} = \frac{1}{2{x}} ##
Related to Find the derivative of this function
1. What is the definition of a derivative?
A derivative is the rate of change of a function at a specific point. It measures how much a function is changing with respect to its input variable.
2. How do you find the derivative of a function?
The derivative of a function can be found using the rules of differentiation, which involve taking the limit of the function as the change in the input variable approaches zero. This process can be simplified by using the power rule, product rule, quotient rule, and chain rule.
3. What does the notation f'(x) mean?
The notation f'(x) represents the derivative of the function f(x). It is also known as the "prime" notation and is read as "f prime of x".
4. What is the difference between a derivative and an antiderivative?
A derivative measures the rate of change of a function, while an antiderivative is the inverse operation of differentiation and finds a function that, when differentiated, equals the original function. In other words, the derivative of a function gives its rate of change, whereas an antiderivative gives the original function back.
5. Why is finding the derivative important?
Finding the derivative of a function allows us to understand the behavior of the function and its rate of change at a specific point. This information is crucial in many areas of science, including physics, engineering, economics, and more. It also helps in solving optimization problems and finding critical points of a function.
