Albert1
- 1,221
$a,b\in R$
$if :\,\,5a^2+8ab+5b^2+170=50a+58b$
please find :$b-a$
please find :$b-a$
Albert said:$a,b\in R$
please find :$b-a$
mathbalarka said:Untrue. A doable solution is :
(1, 5)
solution:Albert said:$a,b\in R$
please find :$b-a$
The purpose of finding the difference between b and a is to determine the numerical value of the amount by which b is greater than or less than a. This can help in various mathematical and scientific calculations.
To calculate the difference between two numbers, you subtract the smaller number from the larger number. The resulting value is the difference between the two numbers.
Yes, the difference between b and a can be a negative number if b is smaller than a. This indicates that a is actually greater than b.
In science, finding the difference between b and a is useful for comparing data and measuring change over time. It can also be used in statistical analysis to determine the significance of experimental results.
The formula for finding the difference between b and a is simply b - a. However, depending on the context and purpose, there may be other formulas or calculations involved in finding the difference between two numbers.
