Find the dimensions of the poster that use the least amount of board
In summary, the problem requires finding the dimensions of a rectangular poster made of cardboard with margins of 2 inches on the top and bottom, and 1 inch on the sides. The area of the poster devoted to printed material must be 300 square inches. To find the dimensions that use the least amount of cardboard, one must use the maximum area formula (A = l x w) and the constraint equation (300 = 2x + y). The width of the printed area can be calculated by subtracting 2 inches from the total width (y) and the height can be calculated by subtracting 4 inches from the total height (x). The area of the printed material can be found by using the formula A = (y-
priscilla98
93
A rectangular poster is to be made out of cardboard. The margins on the top and the bottom will be 2 inches. The margins on the sides will be 1 inch. the are of the poster devoted to the printed material must be 300 square inches.
(a) To the nearest .001 inches, find the dimensions of the poster that use the least amount of cardboard.
(b) To the nearest .001 inches, find the are of the poster that uses the least amount of cardboard.
Area of rectangle = length x width
(a) In this problem we want to find the least amount of cardboard and we know that we will use 300 sq. in. of margins. So, the area will be the function we are trying to optimize and the amount of margins is the constraint. The two equations for these are,
Maximize: A = xy
Contraint: 300 = 2x + y
Am I right so far?
Any help will be greatly appreciated, thanks a lot
You have a basic misunderstanding. You say "we know that we will use 300 sq. in. of margins". That is not true. The problem say that "the are of the poster devoted to the printed material must be 300 square inches." That is the area that is NOT margin.
If the height and width of the poster are x inches and y inches, respectively, how would you calculate the area devoted to the printed material?
Okay, that's true. Wouldn't you change the length and width of the poster from inches to square inches? I know the length of this poster is 2 inches and the width is 1 inch. Therefore, wouldn't the length be 20 inches and the width is 10 inches
I'm sorry but that makes no sense at all. I don't know what you mean by "change the length and width of the poster from inches to square inches". length and width are measured in inches, not square inches. area is measured in square inches. What formula do you know for the area of a rectangle?
No, you do not "know the length of this poster is 2 inches and the width is 1 inch". Those are the widths of the margins, not the dimensions of the poster. And how did you get "20" and "10"?
Perhaps drawing a picture of the poster would help to organize your thoughts.
Okay, then we don't know the length of this poster yet. The area of the poster is 300 sq. in. I know the formula is A = l x w. Knowing that we know the area of the poster, can't we use this to find the dimensions of the poster. The width of the margins is 2 by 1 inches, right?
Of course, we don't know the length of the poster. The problem said to "find the dimensions of the poster"
No, the width of the margins is NOT "2 by 1 inches". There are two margins that are two inches wide and two margins that are 1 inch wide.
If the width of the poster is y inches and 1 inch on either side is taken up for margin, how much is left for the width of the printed area?
If the height of the poster is x inches and 2 inches on to and bottom are taken up for marging, how much is left for the height of the printed area?
So what would a formula for the area, in square inches, of the printed area be?
Related to Find the dimensions of the poster that use the least amount of board
1. How do you find the dimensions of the poster that use the least amount of board?
To find the dimensions of the poster that use the least amount of board, you will need to calculate the area of the poster. Then, you will need to compare the area with the area of the available board. The dimensions that result in the smallest difference between the two areas will use the least amount of board.
2. What is the purpose of finding the dimensions of the poster that use the least amount of board?
The purpose of finding the dimensions of the poster that use the least amount of board is to minimize waste and save resources. By using the least amount of board, you can reduce production costs and also reduce the environmental impact of your project.
3. Can the dimensions of the poster that use the least amount of board be determined using a formula?
Yes, the dimensions of the poster that use the least amount of board can be determined using a formula. The formula for calculating the area of a rectangle is length x width. By manipulating this formula, you can find the dimensions that result in the smallest difference between the poster's area and the available board's area.
4. Are there any other factors to consider when finding the dimensions of the poster that use the least amount of board?
Yes, there are other factors to consider when finding the dimensions of the poster that use the least amount of board. For example, you may need to consider the desired size and proportions of the poster, as well as any constraints or limitations in the available board material.
5. Is there a specific method or algorithm that can be used to find the dimensions of the poster that use the least amount of board?
There are various methods and algorithms that can be used to find the dimensions of the poster that use the least amount of board. Some common approaches include trial and error, mathematical equations, and computer-aided design software. The most suitable method will depend on the specific project and its requirements.
