Find the distinct values of t so that a_{1998}=0
  • MHB
  • Thread starter anemone
In summary, the sequence of real numbers defined by $a_1=t$, $a_{n+1}=4a_n(1-a_n)$ for $n \ge 1$ has two solutions for all $y$ except when $\sin y = 1$, which has only one solution. The values of $a_1$ to $a_{1996}$ are all equal to $\frac{1}{2}$, and the next value, $a_{1997}$ is equal to $1$. Therefore, $a_{1998}$ will be equal to $0$, giving us a total of $2^{1995}+1$ solutions. The predicted solution is $\sin^2\left(\frac
anemone
MHB
POTW Director
3,883
115
Let ${a_n}$ be the sequence of real numbers defined by $a_1=t$, $a_{n+1}=4a_n(1-a_n)$ for $n \ge 1$. For how many distinct values of $t$ do we have $a_{1998}=0$?
Mathematics news on Phys.org
The difference equation can be written as...
$\displaystyle \Delta_{n}= a_{n+1} - a_{n} = 3\ a_{n} - 4\ a^{2}_{n}= f(a_{n})\ (1)$
The f(x) is represented in the pitcure...
http://www.123homepage.it/u/i77203195._szw380h285_.jpg.jfifThere are one attractive fixed point in $\displaystyle x_{1}= \frac{3}{4}$ and one repulsive fixed point in $\displaystyle x_{0}=0$, so that 0 is a repulsive fixed point. That means that 0 can be 'captured' for n=2 only if is...
$\displaystyle a_{1} = t = - \Delta_{1} \implies t - t^{2}= 0\ (2)$
... and that is for t=0 or t=1...
But it is required to find the set of t for which 0 is capured for $\displaystyle n \le 1998$ and that requires further study...
Kind regards
$\chi$ $\sigma$
my solution is not complete but t = 1/2
gives a2 = 1 and then a3 = a4 ... a1998 = 0
it appears that for a1 upto a1997 = 1
for each ofthem there is a different a1 and a1= 0 gives 1998
for example a1 = 1/2 shall give an a0 = (cos pi/4 + 1/2) so it appears much more solution.
In my previous post I wrote that the two possible values of t for which 0 is captured at n=1 are t=0 and t=1...
all right!... now we have to find the possible values of t for which the 1 can be captured at n=1, that means that the 0 will be captured at n=2. These values of t are the solutions of the equation...
$\displaystyle 4\ t^{2} - 4\ t + 1 = 0\ (1)$
... that is the only $\displaystyle t = \frac{1}{2}$. Now we have to search the values of t for which $\frac{1}{2}$ is captured at n=1 so that 0 will be captured at n=3. These values of t are the solutions of the equation...
$\displaystyle 4\ t^{2} -4\ t + \frac{1}{2}= 0\ (2)$
... that are $\displaystyle t = \frac{1}{2} \pm \frac{1}{\sqrt{8}}$. Each of these solutions will generate two solution for n=4 and so one till to n=1998 so that the required number of values of t is...
$\displaystyle N = 2 + \sum_{k=0}^{1996} 2^{k} = 2^{1996}+1\ (3)$
I do hope that nobody ask me to compute them all! (Nerd)...
Kind regards
$\chi$ $\sigma$
1st we should solve
4x(1-x) = sin^2 y
we see that sin ^ 2 y/2 and cos^2 y /2 are roots of equation
2)
this has got 2 solutions for all y except sin y = 1
now counting
a1 = 0 is a solution as all of the values a0 on wards 0
a1 = 1 is a solution as all of the values a2 onwards 0
a1 to a1996 = 1/2 then next value = 1 and so a1998 = 0
a1 =1/2 = one solution
a2 = 1/2 2 solution
a1996 = 1/2 so 2^1995 solution
adding we get 2^1996+ 1 solution
now I predict the the solution is sin^2 ((npi)/(k)/2)
where n is from 0 to 2^1996 and k = 2^1996
this should be the solution
the proof I shall post later
sin^2 ((npi)/(k)/2)
f(sin^2 y) = sin ^2 2y
apply f 1997 times and we get
sin^2 (npi) = 0
done
Hi chisigma and kaliprasad,
Thanks for participating and the answer that both of you have found is correct! Well done!(Clapping)
The solution that I wanted to share here (which isn't my own solution) is as follows:
Let \(\displaystyle f(x)=4x(1-x)=1-(2x-1)^2\).
Observe that if $0 \le f(x) \le 1$, then $0 \le x \le 1$.
Hence if $a_{1998}=0$, then we must have $0 \le t \le 1$.
Now choose $0 \le \theta \le \frac{\pi}{2}$ such that $\sin \theta= \sqrt{t}$.
Observe also that for any $\alpha \in R$,
\(\displaystyle a_1=\sin^2 \alpha\)
\(\displaystyle a_2=f(\sin^2 \alpha)=4\sin^2 \alpha(1-\sin^2 \alpha)=4\sin^2 \alpha\cos^2 \alpha=\sin^2 (2\alpha)\)
\(\displaystyle a_3=f(\sin^2 2\alpha)=4\sin^2 2\alpha(1-\sin^2 2\alpha)=4\sin^2 2\alpha\cos^2 2\alpha=\sin^2 4\alpha=\sin^2 (2^2\alpha)\)
\(\displaystyle a_4f(\sin^2 4\alpha)=4\sin^2 4\alpha(1-\sin^2 4\alpha)=4\sin^2 4\alpha\cos^2 4\alpha=\sin^2 8\alpha=\sin^2 (2^3\alpha)\)
i.e. \(\displaystyle a_{n}=\sin^2 (2^{n-1}\alpha)\)
\(\displaystyle \therefore a_{1998}=\sin^2 (2^{1997}\alpha)\)
In order to have \(\displaystyle a_{1998}=0\), we need \(\displaystyle \sin^2 2^{1997}\alpha=0\), i.e. \(\displaystyle \alpha=\frac{k \pi}{2^{1997}}\) where \(\displaystyle k \in Z\).
Therefore, being bounded by the range of $0 \le \theta \le \frac{\pi}{2}$, we get \(\displaystyle 2^{1996}+1\) such values of $t$ such that \(\displaystyle a_{1998}=0\).
FAQ: Find the distinct values of t so that a_{1998}=0
What is the meaning of "distinct values" in this context?
The term "distinct values" refers to unique or different values. In this case, it pertains to the different values of t that will result in the equation a_{1998}=0 being satisfied.
How do I find the distinct values of t?
To find the distinct values of t, you will need to solve the equation a_{1998}=0. This can be done by manipulating the equation algebraically or by using numerical methods such as graphing or substitution.
Why is it important to find the distinct values of t in this equation?
Knowing the distinct values of t in a_{1998}=0 can provide valuable information about the behavior of the equation and its solutions. It can also help in identifying patterns or relationships between the values of t and the corresponding values of a_{1998}.
Are there any restrictions on the values of t that can satisfy this equation?
Without more context or information about the equation, it is difficult to determine if there are any restrictions on the values of t. However, in general, some equations may have restrictions on the values of t, such as being undefined for certain values or requiring t to be within a certain range.
Can there be more than one distinct value of t that satisfies this equation?
Yes, it is possible for there to be multiple distinct values of t that satisfy the equation a_{1998}=0. This can occur if the equation has multiple solutions or if there are different ways of manipulating the equation to arrive at the same result.
