Find the domain and the range of ##f-3g##
The discussion focuses on determining the domain and range of the function f-3g, defined as f(x) - 3g(x). The domain is established as the intersection of the domains of f and g, specifically for x ≥ 0. The expression for the function simplifies to y = (√x - 3/2)² - 21/4, indicating that the least value occurs at x = 2.25, leading to a range of y ≥ -5.25. Additionally, the function is noted to be unbounded as x approaches infinity, and the use of intersection notation is critiqued for potential confusion.
chwala
The real functions ##f## and ##g## are given by
##f(x)=x-3## and ##g(x)=\sqrt {x}##
Functions
Am refreshing on this,
For the domain my approach is as follows,
##(f-3g)x = f(x)-3g(x)##
##=x-3-3\sqrt{x}##.
The domain of ##f-3g## is given by ##f∩g = [{x: x ≥0}]##
We have
##y= x-3-3\sqrt{x}=(\sqrt x-\frac{3}{2})^2-\dfrac{21}{4}##.
The least value is given by; ##\left(\sqrt x-\dfrac{3}{2}\right)^2 =0##. This occurs when ##x=2.25##.
The range of ##f-3g## is the set ##[{y: y≥-5.25}]##
Your insight or correction is welcome.
Looks good. Maybe a bit complicated but good.
Maybe one observation that may help is that in the final formula, the x term will dominate in going to infinity, so that ##f-3g## will be unbounded. The domain can be determined somewhat simply as the intersection of the domains, while I doubt there's a reasonable conclusion for such formulas as linear combinations of functions.
I would advise against using notation like ##f\cap g##. Intersection is a set operation. ##f## can be regarded as a set of ordered pairs and saying "domain is ##f\cap g##" is confusing the reader.
Whenever both ##f## and ##g## are used to compute a new quantity, it automatically follows that both ##f## and ##g## are well defined, so the domain of interest must be intersection of the individual domains.
Likes SammyS, chwala and fresh_42
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
