Find the domain of the function.
As for why the author chose to factor it in that specific way, I cannot answer that without more context. In summary, the domain of the given function is all real numbers except for $x=-8$ and $x=-1$ due to the presence of a square root. The expression $x^{2}+9x+8$ can be factored into $(x+8)(x+1)$, but the reasoning behind this specific factoring is unclear without more information.
mitchconnor
Find the domain of the real valued function:
f(x)=x−10−−−−−√x2+9x+8=x−10−−−−−√(x+8)(x+1)
Why does the x2+9x+8 become (x+8)(x+1)?
Thanks for the help!
Mathematics news on Phys.org
I'm not entirely sure what mathematical operation is occurring between the $x-10$ and the $\sqrt{x^{2}+9x+8}$. Could you please clarify that for me?
As for $x^{2}+9x+8=(x+8)(x+1)$, that is a straight-forward factoring problem. If you multiply the RHS out, you will get the LHS.
FAQ: Find the domain of the function.
1. What is the domain of a function?
The domain of a function is the set of all possible input values (or independent variables) for the function. In other words, it is the set of values that the function can take.
2. How do you find the domain of a function algebraically?
To find the domain of a function algebraically, you need to look for any value of the independent variable that would make the function undefined. This includes values that would result in division by zero, taking the square root of a negative number, or any other operation that is not defined for certain values. You may also need to consider any restrictions given in the problem, such as a specific range of values for the independent variable.
3. Can the domain of a function be negative numbers?
Yes, the domain of a function can include negative numbers. The domain can be any set of real numbers, including positive, negative, and zero values.
4. What does it mean if the domain of a function is all real numbers?
If the domain of a function is all real numbers, it means that there are no restrictions on the possible input values for the function. In other words, the function is defined for all real numbers.
5. Can the domain of a function be an infinite set?
Yes, the domain of a function can be an infinite set, such as all positive numbers or all negative numbers. This means that the function is defined for an infinite number of input values.
