Find the entropy for the process
In summary, to calculate the change in entropy for the freezing of supercooled water, one must find a reversible path between the initial and final states and calculate the integral of dQ/T for that path. This involves getting the supercooled water from -8C to 0C reversibly, allowing it to freeze at 0C, and then cooling the resulting ice back to -8C.
chemman218
Supercooled water is water that is liquid and yet BENEATH the freezing point.
a) A sample of 131 g of supercooled liquid water freezes to solid ice at a temperature of -8.00 ° C. Using the following,
Cp,ice = 38.09 J/molK
Cp,liquid = 74.539 J/molK
fusH° (at T=0 ° C)=6.01 kJ/mol,
calculate S° for the process. Hint: you must set this up in steps! Report your answer to 3 significant figures.
delta s = CpLn(T2/T1)
delta Sfus = delta Hfus/T
I converted the fusH 6.01kj/mol(131g/18g/mol)=.043 joules
I know Delta S has to be an addition of the steps of freezing the water but am not sure how to get there.
To determine the change in entropy, you have to find a reversible path between the initial and final states and then calculate the integral of dQ/T for that path. Supercooled water freezing at -8C is not reversible. Water freezing at 0C is reversible. So you have to get the supercooled water from -8C to 0C reversibly, let it freeze reversibly, and then cool the ice back to -8C. The change in entropy is the intergral of dQ/T along that path.
AM
Thank you so much for the clarification. It makes more sense now to view it in that process.
Related to Find the entropy for the process
What is entropy?
Entropy is a measure of the disorder or randomness of a system. In thermodynamics, it is a measure of the amount of energy that is unavailable for doing work.
How is entropy calculated?
The entropy for a process can be calculated by taking the ratio of the heat transferred to the temperature at which it is transferred.
What is the unit of measurement for entropy?
The unit of measurement for entropy is joules per kelvin (J/K). It is also commonly expressed in terms of entropy per mole.
What does a positive entropy change indicate?
A positive entropy change indicates an increase in disorder or randomness in the system.
How does entropy relate to the second law of thermodynamics?
The second law of thermodynamics states that the total entropy of a closed system always increases over time. This means that in any process, the overall entropy of the system and its surroundings will always increase, or at best stay the same. Therefore, entropy is closely related to the second law of thermodynamics as it is a measure of the direction in which a process is moving towards increased disorder.
16K
