Find the equaion of the parabola
  • Thread starter r-soy
  • Tags
    Parabola
In summary, we are trying to find the equation of a parabola with its vertex at the origin and axis of symmetry on different points. The answer provided is not correct and the student should work on checking their work and understanding the concepts better.
r-soy
172
Find the equaion of the parabola having its vertex at the origin , its axis as indicated :
A ) x-axis : (-4, - 20 )
b) y - axis : (30,-15 )
C) y - axis : (-root2,3)
my answer
A )
we have (-4, - 20 ) that mean the focus ( - 20 , 0 )
now we do comper 4ay = - 20
= -5
then the equation is : y2 = 4ax
= y2 =4(-5) x
=y2 = -20 x
I sove only number one beacuse i am not sure from my answer
help me Are this solving corect or not ?
I want you ?
These aren't very clear. I guess you mean the axis of symmetry (x-axis or y-axis) and a point on the parabola.
r-soy said:
my answer
A )
Why do you think the focus is at (-20, 0)?
= -5
What equals -5?
= y2 =4(-5) x
=y2 = -20 x
y2 = 4ax is the right equation form, but you don't have the right value for a. The point (-4, -20) should make your equation a true statement, but (-20)2 [itex]\neq[/itex] -20(-4).
You need to get into the habit of checking your work.
Related to Find the equaion of the parabola
1. What is a parabola?
A parabola is a type of curve that is created when a cone is intersected by a plane at a certain angle. It is a symmetrical curve that resembles the shape of a smile or frown.
2. How do you find the equation of a parabola?
The equation of a parabola is typically written in the form y = ax^2 + bx + c, where a, b, and c are constants. To find this equation, you will need to know the coordinates of at least three points on the parabola and then use them to solve for a, b, and c.
3. What is the vertex of a parabola?
The vertex of a parabola is the point at which the curve changes direction. It is the highest or lowest point on the curve, depending on whether the parabola opens upwards or downwards.
4. How do you determine if a parabola opens upwards or downwards?
The direction in which a parabola opens is determined by the value of the coefficient a in the equation y = ax^2 + bx + c. If a is positive, the parabola will open upwards, and if a is negative, the parabola will open downwards.
5. Can a parabola have a negative or zero coefficient?
Yes, a parabola can have a negative or zero coefficient. This will affect the direction in which the parabola opens and the overall shape of the curve.
