Find the equation of a cubic graph
In summary, the homework equations have a graph that is tangent to the x-axis at x=3 and the gradient of that graph is zero.
Helly123
581
##x^3 - 4x^2 + ax + b##
tangent to x-axis at x = 3
if the graph tangent at x = 3, means at x =3, y = 0
my questions is, is at x = 3 the graph's gradient (slope) = 0 ?
if yes why?
if yes then means dy/dx = 0
##3x^2 - 8x + a = 0##
##3.3^2 - 8.3 + a = 0##
##27 - 24 + a = 0##
a = -3
at x=3, y = 0
##3^3 - 4.3^2 - 3.3 + b = 0##
##27 - 39 - 9 + b = 0##
## b = 18 ##
so f(x) = ## x^3 -4x^2 -3x + 18 ##
2nd question :
" find all x such that f(x) has points in common with the x-axis? "
what does it mean by "points in common with the x-axis"?
Yes, if a graph [itex]y = f(x)[/itex] is tangent to the x-axis at point [itex]x_0[/itex], that means that [itex]\frac{df}{dx} = 0[/itex] at [itex]x_0[/itex]. That can be taken as the definition of "tangent": Two curves [itex]f(x)[/itex] and [itex]g(x)[/itex] are tangent at point [itex]x_0[/itex] if they have the same linear approximation at that point:
[itex]f(x_0) = g(x_0)[/itex]
[itex]\frac{df}{dx}|_{x=x_0} = \frac{dg}{dx}|_{x=x_0}[/itex]
If the curve [itex]y = g(x)[/itex] is the x-axis, then [itex]g(x) = \frac{dg}{dx} = 0[/itex]
Well, the x-axis is the set of points [itex](x,y)[/itex] such that [itex]y=0[/itex]. A graph [itex]y=f(x)[/itex] is the set of points [itex](x,y)[/itex] such that [itex]f(x) = y[/itex]. So the points in common between the x-axis and that graph are the sets of all points [itex](x,0)[/itex] such that [itex]f(x) = 0[/itex].
Likes Helly123
Just think - if the slope at this point (3, 0) were not zero then the curve is pointing upwards near this point if the slope is positive, or downwards if it is negative. In either case it goes from under the x-axis to over it - it is not tangent there. They have given you an example which makes it easy to see, because it is tangent actually on the x axis. But general you will get problems with minima and maxima that are not on the x-axis, just imagine a different horizontal line(y = C) instead of the x-axis in the minimum or maximum is tangent to that.
If you think back you were probably explained this in class - get it clear because it is going to come in all the time in calculus.
Likes Helly123
FAQ: Find the equation of a cubic graph
How do you find the equation of a cubic graph?
To find the equation of a cubic graph, you need to know the coordinates of at least three points on the graph. Then, you can use the general form of a cubic function, y = ax^3 + bx^2 + cx + d, to plug in the coordinates and solve for the coefficients a, b, c, and d.
What is the general form of a cubic function?
The general form of a cubic function is y = ax^3 + bx^2 + cx + d, where a, b, c, and d are constants. The coefficient a determines the steepness of the graph, while b, c, and d affect the position and shape of the graph.
Can a cubic graph have more than one equation?
Yes, a cubic graph can have multiple equations depending on the number of points given. Generally, a cubic graph requires at least three points to determine a unique equation. However, if you have more than three points, you can use the method of least squares to find the best-fit cubic equation for the data.
How can I check if my equation is correct for a cubic graph?
To check if your equation is correct for a cubic graph, you can plot the graph of the equation and compare it to the original cubic graph. If the two graphs match, then your equation is correct. You can also plug in the coordinates of known points on the cubic graph into the equation to see if it produces the same y-values.
Are there any special cases when finding the equation of a cubic graph?
Yes, there are two special cases when finding the equation of a cubic graph:
  • If the cubic graph has a y-intercept of 0, the equation will not have a constant term (d = 0).
  • If the cubic graph has symmetry about the origin, the equation will have a coefficient of 0 for the linear term (c = 0).
