Find the equation of a parabola
  • Thread starter Thread starter ChieF.
    Parabola
To find the equation of the parabola with a range of Y <= 8, the vertex must be at (-4, 8). The y-intercept of -6 provides a point through which the parabola passes. By substituting these values into the vertex form of the equation, the coefficient 'a' can be determined, which must be negative since the parabola opens downward. The initial attempts to solve the equation resulted in a tautology (0 = 0) due to not fully utilizing the vertex information. Understanding that the vertex is at (-4, 8) is crucial for correctly finding the equation.
ChieF.
Find the equation of a parabola with the following characteristics:
range Y <= 8
x-coordinate of the turning point is -4
y-intercept = -6
I have tried to substitute all the information into y = a(x-p)^2 + q
which gives me y = a(x+4)^2 + q and substituted the y-intercept into the equation and then subbed in q into the equation with the y-intercept subbed in as well but that just came up as 0 = 0
Here is my working out
Sub y-intercept into equation
-6 = a(0 +4)^2 +q
-6 = 16a + q
q = -6 -16a
Sub into equation (0,-6) and q
-6 = a(0+4)^2 - 16a -6
0 = 16a - 16a
0 = 0
range Y <= 8
y-intercept = -6
-6 = a(0 +4)^2 +q
-6 = 16a + q
q = -6 -16a
0 = 16a - 16a
0 = 0
Well, of course, solving for q using the y intercept and then putting the y-intercept into the equation will give you 0= 0! What did you expect?
You haven't used all of the information. The fact that "range y<= 8" tells you that the vertex is at (-4, 8). That tells you both p and q. After you know p and q, the fact that the parabola passes through (0, -6) will give you a, which must be negative as the parabola opens downward.
I'm assuming that "turning point" = "vertex"...
If "range Y <= 8" then doesn't that imply that the y-coordinate of the vertex is 8? Can you take it from there?EDIT: Beaten to the punch by HallsofIvy! ;)
01
thanks for the help
  • · Replies 20 ·
