MHB Find the equation of the tangent and normal to.
  • Thread starter Thread starter Nemo1
    Normal Tangent
Nemo1
Hi Community,
I have this question.
View attachment 5059I start by creating the derivative,
$$\d{}{x}(x^2-xy+y^2) = \d{}{x}(3) $$
and solve for $$\d{}{x}(3) $$ = 0 (Derivative of a constant is alway 0)
I understand how to solve the derivative of
$$\d{}{x}(x^2-xy+y^2)$$
and get $$2x-y$$
In the worked example it says:
$$2x-y-x\d{}{x}+2y\d{}{x}=0 \implies 2x-y=(x-2y)\d{y}{x}$$
Which becomes,
$$\d{y}{x}=\frac{2x-y}{x-2y}$$
I am lost at the previous step as I don't know where $$-x\d{y}{x}$$ and the $$+2y\d{y}{x}$$ come from?
I am wondering if I should be using the sum/differential rule $$(f \pm g)^{\prime}= f^{\prime} \pm g^{\prime}$$
I would like to fully understand the process for finding the derivative and how to plug it into solve for the tangent and normal to lines.
Many thanks for your time in advance.
Nemo
Nemo said:
Hi Community,
and get $$2x-y$$
Which becomes,
Nemo
The reason is that you have taken y to be a constant but it is a function of x and so the product rule shall apply and the worked example is correct
Hello Nemo! :)
In your following step:
Nemo said:
...I understand how to solve the derivative of
and get $$2x-y$$...
you are treating $y$ as a constant, when in fact it is a function of $x$, so you need to differentiate term by term, and use the product, power and chain rules:
$$\d{}{x}\left(x^2-xy+y^2\right)=\d{}{x}\left(x^2\right)-\d{}{x}\left(xy\right)+\d{}{x}\left(y^2\right)$$
Let's look at each term individually:
$$\d{}{x}\left(x^2\right)=2x$$
$$\d{}{x}\left(xy\right)=x\d{y}{x}+y$$
$$\d{}{x}\left(y^2\right)=2y\d{y}{x}$$
And so we have:
$$\d{}{x}\left(x^2-xy+y^2\right)=2x-x\d{y}{x}-y+2y\d{y}{x}=0$$
Now we solve for $$\d{y}{x}$$ by arranging all terms with this as a factor on the left, and everything else on the right:
$$-x\d{y}{x}+2y\d{y}{x}=y-2x$$
Factor:
$$\d{y}{x}(2y-x)=y-2x$$
And finally divide through by $2y-x$ to get:
$$\d{y}{x}=\frac{y-2x}{2y-x}$$
So, what must the slope of the tangent and normal lines be at the given point on the curve?
Light bulb moment! thanks Mark & kaliprasad,
So following on from $$\d{y}{x}=\frac{y-2x}{2y-x}$$ in Marks reply.
Looks very familiar to the $$mx=\frac{y2-y1}{x2-x1}$$
I could then write:
$$mx=\frac{2-2(1)}{2(2)-1}$$
to get the slope which when calculated equals $$0$$ so I know my tangent line is horizontal at point $$(1,2)$$
Therefore the normal to is going to be $$90$$ degrees which is $$x=1$$
As per my graph below.
Please let me know if I am in the ball park and if there is a clearer way to prove it.
Cheers
Nemo.
What I would do is use the expression we obtained for $$\d{y}{x}$$ and the given point to determine the slope of the tangent line:
$$\left.\d{y}{x}\right|_{(x,y)=(1,2)}=\frac{2-2(1)}{2(2)-1}=0$$
So, we know the tangent line is horizontal, and since it must pass through the point $(1,2)$, this line is:
$$y=2$$
Since a line normal to a horizontal line must be vertical, and it must pass through the given point, it will be:
$$x=1$$
If the tangent line had not been horizontal, then we we take the value of the slope, along with the given point and used the point-slope formula to determine the equation of the tangent line. Then to find the normal line, we would use the fact that the product of the slope of two normal lines is -1, and then again used the point-slope formula.
We kind of had it easy here because the tangent line is horizontal. :)
