Find the equation of the tangent in the given problem
  • Thread starter Thread starter chwala
    Tangent
chwala
See attached
Differentiation
The textbook solution is indicated below;
My approach on this question is as follows;
##\dfrac{dy}{dx} = -\dfrac {8}{x^3}##
##\dfrac{dy}{dx} (x=a) = -\dfrac {8}{a^3}##
The tangent equation is given by;
##y= -\dfrac {8}{a^3}x+\dfrac{12+a^2}{a^2}##
when ##x=0##,
##y=\dfrac{12+a^2}{a^2}##
and when ##y=0##,
##\dfrac {8}{a^3} x = \dfrac{12+a^2}{a^2}##
##⇒\dfrac {8}{a^2}=y##
##⇒\dfrac {8}{a^2}=\dfrac{4}{a^2} +1##
##8=4+a^2##
##4=a^2##
##a=\sqrt{4}=2##
on using; ##y=\dfrac{12+a^2}{a^2}## and substituting ##a=2## yields
##y=\dfrac{12+2^2}{2^2}=\dfrac{16}{4}=4##
##b=4##.
I would appreciate any other method or insight. Cheers guys!
What happened to ##a=-2## at ##y=0##?
I think your method is fine, no need to make things more complicated.
chwala said:
Homework Statement:: See attached
Relevant Equations:: Differentiation
View attachment 316098The textbook solution is indicated below;
when ##x=0##,
and when ##y=0##,
##8=4+a^2##
##4=a^2##
##a=\sqrt{4}=2##
##b=4##.
My only thought is that, once you get the slope, the line that passes through the point (0, b) is ##(y - b) = m(x - 0 )##, and the line through (b, 0) is ##(y - 0) = m(x - b)##. You can solve those simultaneously. However I don't think that approach gets you anything that much simpler.
-Dan
You are right; ##a=±2##, We shall treat ##a=-2## as unsuitable as it will not realize the required co-ordinates at the ##x## axes, that is ##(b,0)## and ##y## axes, that is ##(0,b)##.
The conditions on the tangent line intersecting the axes require that its equation be <br /> f(a) + f&#039;(a)(x - a) = \frac{12}{a^2} + 1 - \frac{8}{a^3}x = y = b - x. Comparing powers of x gives <br /> \begin{split}<br /> \frac{12}{a^2} + 1 &amp;= b \\<br /> \frac{8}{a^3} &amp;= 1.\end{split} These are easily solved to find a = 2 and b = 4.
