Find The Exact Value of A Definite Integral
In summary, we were unable to find an exact value for the given definite integral, but we were able to simplify it to \displaystyle \begin{align*} 2\sin{(2)} \end{align*} using different approaches. It is possible that there is no closed form solution for this integral.
anemone
MHB
POTW Director
3,883
115
Find the exact value of the following definite integral:
\(\displaystyle \int_0^2 (3x^2-3x+1)\cos (x^3-3x^2+4x-2)\,dx\)
Mathematics news on Phys.org
Interesting problem! I noticed neither my calculator (TI-89) nor W|A could come up with the exact result. Here is my approach:
Let:
\(\displaystyle I=\int_0^2\left(3x^2-3x+1 \right)\cos\left(x^3-3x^2+4x-2 \right)\,dx\)
Observe that:
\(\displaystyle x^3-3x^2+4x-2=(x-1)^3+(x-1)\)
\(\displaystyle 3x^2-3x+1=3x(x-1)+1\)
So, let:
\(\displaystyle u=x-1\,\therefore\,du=dx\)
and we have:
\(\displaystyle I=\int_{-1}^{1}\left(3u^2+3u+1 \right)\cos\left(u^3+u \right)\,du\)
\(\displaystyle I=\int_{-1}^{1}\left(3u^2+1 \right)\cos\left(u^3+u \right)\,du+3\int_{-1}^{1}u\cos\left(u^3+u \right)\,du\)
By the odd-function rule, this reduces to:
\(\displaystyle I=\int_{-1}^{1}\left(3u^2+1 \right)\cos\left(u^3+u \right)\,du\)
Let:
\(\displaystyle v=u^3+u\,\therefore\,dv=\left(3u^2+1 \right)\,du\)
and we have (using the even-function rule):
\(\displaystyle I=2\int_0^2\cos(v)\,dv=2\sin(2)\approx1.8185948536513634\)
What a great solution, MarkFL!(Sun)
I have a slightly different approach to Mark's...
\(\displaystyle \displaystyle \begin{align*} \int_0^2{ \left( 3x^2 - 3x + 1 \right) \cos{ \left( x^3 - 3x^2 + 4x - 2 \right) } \,dx } \\ = \int_0^2{ \left( 3x^2 - 6x + 4 \right) \cos{ \left( x^3 - 3x^2 + 4x - 2 \right) } \, dx} + \int_0^2{ \left( 3x - 3 \right) \cos{ \left( x^3 - 3x^2 + 4x - 2 \right) } \,dx } \end{align*}\)
The first integral can be solved using \(\displaystyle \displaystyle \begin{align*} u = x^3 - 3x^2 + 4x - 2 \implies du = \left( 3x^2 - 6x + 4 \right) \, dx \end{align*}\) giving
\(\displaystyle \displaystyle \begin{align*} \int_0^2{ \left( 3x^2 - 6x + 4 \right) \cos{ \left( x^3 - 3x^2 + 4x - 2 \right) } \, dx} &= \int_{-2}^2{ \cos{(u)}\,du } \\ &= \left[ \sin{(u)} \right]_{-2}^2 \\ &= \sin{(2)} - \sin{(-2)} \\ &= \sin{(2)} + \sin{(2)} \\ &= 2\sin{(2)} \end{align*}\)
As for the second
\(\displaystyle \displaystyle \begin{align*} \int_0^2{ \left( 3x - 3 \right) \cos{ \left( x^3 - 3x^2 + 4x - 2 \right) } \, dx } &= 3 \int_0^2{ \left( x - 1 \right) \cos{ \left[ \left( x - 1 \right) \left( x^2 - 2x + 2 \right) \right] } \, dx } \\ &= 3\int_0^2{ \left( x - 1 \right) \cos{ \left\{ \left( x - 1 \right) \left[ \left( x - 1 \right) ^2 + 1 \right] \right\} } \, dx } \end{align*}\)
Now let \(\displaystyle \displaystyle \begin{align*} v = x - 1 \implies dv = dx \end{align*}\) and the integral becomes
\(\displaystyle \displaystyle \begin{align*} 3\int_{-1}^1{ v \cos{ \left[ v \left( v^2 + 1 \right) \right] } \, dv } &= 0 \end{align*}\)
because it's an odd function integrated over an even region.Therefore, the original integral equals \(\displaystyle \displaystyle \begin{align*} 2\sin{(2)} \end{align*}\)
To find the exact value of this definite integral, we can use the fundamental theorem of calculus. First, we can integrate the given function (3x^2-3x+1)\cos (x^3-3x^2+4x-2) with respect to x, which will give us a new function. Then, we can evaluate this new function at the upper and lower limits of integration (0 and 2 in this case), and subtract the two values to get the exact value of the definite integral.
This process may require some algebraic manipulation and possibly integration by parts, depending on the complexity of the function. It is important to note that the exact value of a definite integral cannot always be found using analytical methods, in which case numerical methods such as numerical integration or approximation techniques may be used.
In summary, to find the exact value of a definite integral, we must integrate the given function, evaluate it at the upper and lower limits of integration, and subtract the two values. If the function is too complex to be evaluated analytically, numerical methods may be used instead.
FAQ: Find The Exact Value of A Definite Integral
What is a definite integral?
A definite integral is a mathematical concept used in calculus to calculate the area under a curve on a specific interval. It is represented by the symbol ∫ and is composed of a function to be integrated, the variable of integration, and the interval over which the integration is performed.
What is the difference between definite and indefinite integrals?
A definite integral has specific limits of integration, while an indefinite integral does not. This means that a definite integral will yield a numerical value, while an indefinite integral will result in a function with a constant of integration.
How do you find the exact value of a definite integral?
To find the exact value of a definite integral, you must first evaluate the indefinite integral and then substitute the limits of integration into the resulting function. This will give you a numerical value for the area under the curve on the specific interval.
What are the different methods for finding the exact value of a definite integral?
There are several methods for finding the exact value of a definite integral, including the fundamental theorem of calculus, integration by parts, u-substitution, and trigonometric substitution. The method used will depend on the complexity of the function being integrated.
Why is finding the exact value of a definite integral important?
Finding the exact value of a definite integral is important because it allows us to calculate the area under a curve, which has many real-world applications. It also helps us to solve problems in physics, engineering, and other scientific fields where the concept of integration is used.
