MHB Find the exact value of each of the remaining trigonometric functions of theta
Given that sin(θ) = 3/5, the discussion focuses on finding the remaining trigonometric functions. Since sin(θ) is positive, θ is in Quadrant I or II. Using the Pythagorean identity sin²(θ) + cos²(θ) = 1, cos(θ) can be calculated as √(1 - (3/5)²), resulting in cos(θ) = 4/5. The values for tan(θ), sec(θ), csc(θ), and cot(θ) can then be derived from sin(θ) and cos(θ). The thread emphasizes the importance of understanding trigonometric identities for solving such problems.
adrianaiha
sin\theta 3/5
Mathematics news on Phys.org
I've moved this thread to our Trigonometry forum, since this is not a calculus problem, but involves trig. instead.
I am assuming you've been given:
$$\sin(\theta)=\frac{3}{5}$$
And you are to find the values of the other 5 trig. functions as a function of $\theta$.
Since the sine of $\theta$ is positive, we know that $\theta$ is in either Quadrant I or II. To find the cosine of $\theta$, let's consider the Pythagorean identity:
$$\sin^2(\theta)+\cos^2(\theta)=1$$
Solve this for $\cos(\theta)$, and plug in the given value for $\sin(\theta)$...what do you get?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
