MHB Find the exact value of the solution to the equation √ 2+(√ 2-(√ 2+√( 2-x))))=x.
  • Thread starter Thread starter anemone
    Value
The equation √2 + (√2 - (√2 + √(2 - x))) = x can be simplified to √2 + √(2 - x) = x. This leads to the fourth-order polynomial equation x^4 - 4x^2 + x + 2 = 0, which factors into (x - 1)(x + 2)(2x - √5 - 1)(2x + √5 - 1) = 0. The solutions include x = 1 and x = (1 + √5)/2, with the latter being validated as a suitable solution. The discussion emphasizes the periodicity of solutions and the iterative nature of the equation's structure.
anemone
MHB
POTW Director
$ \sqrt {2 +\sqrt {2-\sqrt{2+\sqrt{ 2-x}}}}=x $
I wanted so much to share with you all this question because it's an easy yet the tricky one, imho.
Mathematics news on Phys.org
Re: Find the exact value of the solution to the equation √ 2+(√ 2-(√ 2+√( 2-x))))=x.
If You consider the first order difference equation...
$\displaystyle a_{n+1}= \sqrt{2-(-1)^{n}\ a_{n}}\ ;\ a_{0}=x$ (1)
... Your problem is the search of solutions of (1) with periodicity 4.In order to symplify the procedure You can start searching solutions of periodicity 2 that, of course, are also solutions with periodicity 4. The solutions with periodicity 2 are solutions of the equation...
$\displaystyle \sqrt{2+\sqrt{2-x}}=x$ (2)
... i.e. a non negative solution of the fourth order equation...
$x^{4} -4\ x^{2} + x + 2= (x-1)\ (x+2)\ (x^{2}-x-1)=0$ (3)
... that are $\displaystyle x_{1}=1$ and $\displaystyle x_{2}=\frac{1 + \sqrt{5}}{2}$. A simple test shows that $x_{2}$ is 'good solution'. Other solutions with periodicity 4 are to be found...
Kind regards
$\chi$ $\sigma$
$$ \sqrt {2 +\sqrt {2-\sqrt{2+\sqrt{ 2-x}}}}=x $$
Write this as:
$$\sqrt{2 +\sqrt {2-\sqrt{2+\sqrt{ 2-\sqrt {2 +\sqrt {2-\sqrt{2+\sqrt{ 2-x}}}}}}}}=x $$
Again write this as:
$$\sqrt{2 +\sqrt {2-\sqrt{2+\sqrt{ 2-\sqrt {2 +\sqrt {2-\sqrt{2+\sqrt{ 2-\sqrt {2 +\sqrt {2-\sqrt{2+\sqrt{ 2-x}}}}}}}}}}}}=x $$
Repeat this procedure till infinity.
$$\sqrt{2 +\sqrt {2-\sqrt{2+\sqrt{ 2-\sqrt {2 +\sqrt {2-\sqrt{2+\sqrt{ 2-\sqrt {2 +\sqrt {2-\sqrt{2+\sqrt{ 2-\cdots}}}}}}}}}}}}=x $$
This means
$$\sqrt{2+\sqrt{2-x}}=x$$
Take squares of both sides
$$2+\sqrt{2-x}=x^2 \quad \quad \cdots (1)$$
Multiply both sides by $2-\sqrt{2-x}$:
$$2-\sqrt{2-x}=\frac{2+x}{x^2} \quad \quad \cdots (2)$$
Add (1) and (2):
$$4=x^2+ \frac{2+x}{x^2}$$
$$x^4-4x^2+x+2=0$$
Factorize:
$$(x-1)(x-2)(2x-\sqrt{5}-1)(2x+\sqrt{5}-1)=0$$
This gives:
$$x=\frac{1}{2}(\sqrt{5}+1)$$
which is the desired solution.
Kind regards
$\chi$ $\sigma$
Hi chisigma, you're always capable of solving all kinds of maths-related questions using some sophisticated approachs, huh?
You're awesome!
Write this as:
This means
I see it this way:
Since $ f^{-1} (f(x))=x $, and we're given $ \sqrt {2 +\sqrt {2-\sqrt{2+\sqrt{ 2-x}}}}=x $,
then if I solve the following for x,
$\sqrt{2+\sqrt{ 2-x}}=x$
that means I solve the original equation for x too.:)
(By using your way or substitution method.)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
