Find the expression for the frequency emitted if the source
In summary, the problem involves finding the expression for the frequency emitted by a stationary wave source in terms of the measured frequencies and wave speed. The relevant equation is fr=(fs)/(1±u/v) and by plugging in the variables for the two given situations, two equations can be obtained to solve for fs without u.
grapejellypie
A wave source approaches you at constant speed and you measure a wave frequency f1. As the source passes and then recedes, you measure frequency f2. Find the expression for the frequency emitted if the source were stationary in terms of f1, f2, and wave speed v.
I'm not sure which equations are relevant, but here are some:
f=v/λ (where λ = wavelength)
for situations in which the source is in motion relative to a stationary receiver
fr=(fs)/(1±u/v) where fr=frequency the receiver receives; fs= frequency emitted by source, u=speed of source, and v= wave speed)
I'm not sure how to go about solving this problem. I know that the answer will be in terms of variables...
I also know that fs= fr when the source and receiver are stationary
grapejellypie said:
... for situations in which the source is in motion relative to a stationary receiver
That's the equation to use here. Plug in the variables for the 2 situations given, to get 2 equations in the 2 "unknowns" fs and u. Ultimately you want an expression for fs that does not contain u.
with respect to each other.
I would approach this problem by first understanding the concept of Doppler effect. The Doppler effect is the change in frequency of a wave when the source or observer is in motion relative to each other. In this case, the source is in motion relative to the observer.
To find the expression for the frequency emitted, we can use the Doppler effect equation:
f = f0 * (v + u) / (v + vs)
Where f0 is the frequency emitted by the source when it is stationary, v is the wave speed, u is the speed of the source, and vs is the speed of the observer. In this case, vs is zero as the observer is stationary.
Now, we can substitute the given frequencies f1 and f2 for f0 and solve for fs:
f1 = fs * (v + u) / v
f2 = fs * (v - u) / v
Solving for fs, we get:
fs = f1 * v / (v + u)
or
fs = f2 * v / (v - u)
Therefore, the expression for the frequency emitted by the source when it is stationary is:
fs = (f1 * f2 * v) / (f2 * u + f1 * v)
or
fs = (f1 * f2 * v) / (f1 * u + f2 * v)
I hope this helps in solving the problem.
Related to Find the expression for the frequency emitted if the source
1. What is the formula for finding the frequency emitted by a source?
The formula for finding the frequency emitted by a source is: frequency = speed of light / wavelength. This is also known as the equation for wave speed.
2. How do I determine the speed of light in the formula for frequency?
The speed of light is a constant value, which is approximately 3 x 10^8 meters per second. This value can be found in most physics or science textbooks, or can be easily searched online.
3. Can the frequency emitted by a source change over time?
Yes, the frequency emitted by a source can change over time. This can happen due to various factors such as the movement of the source, changes in temperature or pressure, or interference from other sources.
4. What is the relationship between frequency and wavelength?
The frequency and wavelength of a wave are inversely proportional. This means that as the frequency increases, the wavelength decreases, and vice versa. This relationship is described by the formula: frequency = speed of light / wavelength.
5. Can the formula for frequency be used for all types of waves?
No, the formula for frequency (frequency = speed of light / wavelength) is specific to electromagnetic waves. Other types of waves, such as sound waves, have their own equations for determining frequency.
