Find the expression for the sum of this power series
In summary: But why does that matter when the expression has been re-written? isn't is possible to solve it from the re-written...Yes, it is possible to solve it from the re-written expression, but the q term will not cancel and you will get x^2*e^x.Yes, it is possible to solve it from the re-written expression, but the q term will not cancel and you will get x^2*e^x.
Kqwert
160
Hello,
I need to find an expression for the sum of the given power series
I think that one has to use a known Maclaurin series, for example the series of e^x. I know that I can rewrite
, which makes the expression even more similar to the Maclaurin series for e^x. Any help?
This is a good idea. You may want to use the fact that ##n = (n-1) + 1## rather than going for getting ##n!## in the denominator though.
How does that help me?
Did you try doing it?
Likes PeroK
Yes, but not sure what it helps me? Should I replace all n's in the expression by n = (n-1)+1?
No, just in the numerator to split your sum into two.
It also helps if you state what you get when you do so - otherwise I have to guess what stage you are at.
So I get this expression?
I assume you mean ##x^n##. So split it into two sums and treat each sum separately. You may want to simplify the second term change the summation variable in both sums.
Yeah, I mean x^n! What do you mean by change the summation variable. Is it like write k = n-1?
Yes, that could be a reasonable substitution for one of the terms.
What about the last term though? Not sure what the best simplification of that is.
What is ##(n-1)/(n-1)!##?
You can split that expression into two as well..?
What is ##(n-1)!##?
(n-1)(n-2)(n-3)(n-4) etc.. I guess you can write 1/(n-2)!, but doubt that is it?
Why do you doubt that?
Hm, I guess I can substitute k = n-2, which makes it into the exponential Maclaurin Series?
Does it? What exactly do you obtain?
So i am getting a little lost here.
This is where we are right?
By substituting k = n-1 into the first expression we get a very similar expression to the e^x series,
in the second expression we can do q = n - 2 and get..
is this the way?
You are making good progress. So what is the difference between the two series that you have obtained and the expansion of ##e^x##?
Just x and x^2, respectively, which are not dependent on n. However, what happens when I do the variable changes and calculate the sums? For k = n-1 we get k = 0 as the lower sum and k = inf. as the upper sum, while we get q = -1 as the lower and q = inf as the upper for the second expression?
Yes, this is indeed the next thing you must check. For the k sum, you are already fine since the exponential series expansion is a sum from zero. For the q sum, what is ##(n-1)/(n-1)!## when ##n = 1##? Does that term contribute?
It´s just zero. But, the way I have done it. I´m left with
WolframAlpha gave me x^2*e^x, but why..? I know that we must get q = 0, which results in x^2*e^x, but doesn't the q = -1 term contribute?
You have to treat that term separately. Before cancelling (n-1)/(n-1)! to 1/(n-2)!, note that the n = 1 term reads 0/0!
But why does that matter when the expression has been re-written? isn't is possible to solve it from the re-written series?
Because the rewriting is not correct for ##n = 1##.
Not sure If I understand what you mean?
For ##n = 1##, the term reads ##0/0!## but with the "cancellation" you did, it would be ##-1/(-1)!##, which you would need to interpret in terms of the Gamma function ##\Gamma(x)## in the limit ##x \to 0##, where ##\Gamma(x) \to \infty##. It is much easier to just remove that term from the beginning since 0! = 1 and therefore 0/0! = 0/1 = 0.
Ok thanks, but how does that relate to the "q-series" I´ve found which starts at q = -1? Wrong way of doing it?
You only found that particular series by making the cancellation. Alternatively you can do the replacement before cancellation, you will then get ##(q+1)/(q+1)!## and you can note that the ##q = -1## term is zero because ##q+1 = 0## so you can remove it. After that the cancellation is fine for all terms.
  • #31
Thank you, but what cancellation? Re-writing (n-1)/(n-1)! to 1/(n-2)! ? Not sure if I understand exactly what happens and why.
  • #32
Yes, that cancellation. Because, as I said in #24, for ##n = 1##, that term reads ##0/0!## and the terms you would cancel are 0 and 0, which you cannot do. You have to look at that term separately and realize that it is actually zero so that it gives no contribution.
  • #33
I understand that, but I don't understand the order of things. When we start from
Should we first say that
and then do the change of variables? I am becoming a bit confused re. the best way of solving this.
  • #34
What you had from the beginning was
\sum_{n=1}^\infty \frac{(n-1)x^n}{(n-1)!},
not the sum from ##n = 0##. It does not matter if you change variables first or if you do the cancellation first. The only thing you must do is to remove the term ##n = 1## (or equivalently ##q = -1##) before you do the cancellation because that step is not valid for that term.
  • #35
And by removing the n = 1 term we end up starting at n = 2, right?
