Find the extra force required to maintain the speed of the belt
In summary, the problem involves finding the extra force needed to maintain the speed of a coal conveyor belt, with a rate of 540 tonnes per hour and a velocity of 2.0 m/s. Using Newton's second law, the force is equal to the rate of change of momentum. After calculating the initial and final momentums, the change in momentum can be divided by the change in time to find the force required, which is equivalent to 300 N.
Doubell
29
coal is falling onto a conveyor belt at a rate of 540 tonnes every hour. the belt is moving horizontally at 2.0 ms-1. find the extra force required to maintain the speed of the belt. (1 tonne=1000kg.)
F=m*a
i tried to solve by saying that F=m*a. so to find force i would need the accelaration of the belt and multiply it by the mass of the coal. the acceleration is the rate of change of velocity so i would use the 2ms-1 as the final velocity and 0 ms-1 as the annitial subtracting 0 from two leaves 2 ms-1 and i divide by the rate of change of time which is 3600s.this leaves me with an accelaeration of 0.000556 ms/s^2 multiplying this by the mass of the coal 540000kg leaves 300 N. is this right
I'm not too sure on that problem. What I think I can advise however is a few things.
You are trying to maintain the speed, this means that
final velocity and initial velocity are both 2 m/s which means that
v-v_0=at
2m/s - 2m/s = at
0=at
so there is no acceleration.
If you take the 540,000kg/h and convert it into seconds you get 150kg/s . So now you know how much the mass is increasing by per second and the acceleration.
Using dimensional analysis, we have 150 kg/s and 2.0 m/s , if we multiply these values, we get 300 kg.m/s^2 which is a Newton , so I believe the answer is 300 N like you suspected. However I would also check with others as I am not certain on this.
i just looked at it and found out another solution. in accordance to Newton's second law force = rate of change of momentum. the innitial momentum that occurred in 1 second would be 150kg *2 ms-1 (mass x velocity) which equals 300 kg ms-1 the final momentum that occurred in 3600 seconds would be 540000kg *2 ms-1.( the final and innitial velocities are the same) which = 1080000 kg ms-1. change in momentum = final momentum - innitial momentum this equals 1079700 kg ms-1. the change in time = T2-T1 = 3600s-1s which gives 3599s. Now in accordance to Newtons second law the rate of change of momentum = force this implies that change in momentum(1079700 kg ms-1) divided by change in time(3599s) = 300 kg m/s^2 =300N
FAQ: Find the extra force required to maintain the speed of the belt
What is the extra force required to maintain the speed of the belt?
The extra force required to maintain the speed of the belt is the additional force needed to counteract any friction or resistance on the moving belt and keep it moving at a constant speed.
How do you calculate the extra force required to maintain the speed of the belt?
The calculation for the extra force required depends on the specific variables of the belt, such as its weight, length, and the surface it is moving on. It can be calculated using the formula F=ma, where F is the extra force, m is the mass of the belt, and a is the acceleration of the belt. This formula takes into account the belt's inertia and any frictional forces acting against it.
What factors affect the extra force required to maintain the speed of the belt?
The extra force required to maintain the speed of the belt can be affected by several factors, including the weight and length of the belt, the type and condition of the surface it is moving on, and any additional forces acting on the belt, such as tension or resistance from other objects.
How does the extra force required to maintain the speed of the belt impact the overall efficiency of a machine?
The extra force required to maintain the speed of the belt can have a significant impact on the overall efficiency of a machine. This extra force represents energy that must be supplied to the belt to keep it moving, and any additional energy required can decrease the efficiency of the machine. Therefore, minimizing the extra force required is important for maximizing the efficiency of a machine.
How can the extra force required to maintain the speed of the belt be reduced?
The extra force required to maintain the speed of the belt can be reduced by minimizing friction and resistance on the belt. This can be achieved by using proper lubrication, reducing the weight of the belt, and ensuring the surface it is moving on is smooth and clean. Additionally, proper tension and alignment of the belt can also help reduce the extra force required to maintain its speed.
