Find the First 4 Terms of Two Linear Solutions for y"+xy'-5y=0 at x=0
In summary: Again, the coefficient of x^-6 is 0, which means that the solution cannot be written as a power series in x. We will have to consider another value of n.In summary, we have found that the first 4 terms of each of the two linear independent solutions for the given equation cannot be determined using the power series method. We will have to explore other methods to find the solutions. I hope this helps guide you in the right direction. Best of luck to you and your son on the exam!
qasker101
Find the first 4 terms of teach of the two linear independent solutions oftheEQUATION
y"+xy'-5y=0 a the ordinary point x=0
I am stuck at the circled part of the question and unable to proceed. Any guidance and help is appreciated!
I have attached an image with the part till which I got to circled in red. Please advise me on how to proceed! This is a problem my son is practicing for his exam for his DQ class. The attached scan is a copy of solution that his friend had who is unreachable at the moment.
Hello there,
Thank you for reaching out for help with this problem. I am more than happy to assist you in finding the first 4 terms of each of the two linear independent solutions for the given equation.
First, let's start by writing out the given equation in its standard form:
y'' + xy' - 5y = 0
Since the given point is an ordinary point (x=0), we can use the power series method to find the solutions. We will assume that the solutions can be written as a power series in x:
y = ∑n=0∞ anxn
Substituting this into the given equation, we get:
∑n=2∞ n(n-1)anxn-2 + ∑n=1∞ anxn+1 - 5∑n=0∞ anxn = 0
Now, we can group the terms according to their powers of x:
∑n=0∞ (n+2)(n+1)an+2xn + ∑n=0∞ (n+1)an+1xn - 5∑n=0∞ anxn = 0
Next, we can equate the coefficients of each power of x to 0, starting with x^0:
(n+2)(n+1)an+2 + (n+1)an+1 - 5an = 0
Simplifying this, we get:
(n+2)(n+6)an+2 = 0
Therefore, we have two possible values for n: n = -2 or n = -6. We will consider each of these cases separately.
Case 1: n = -2
Substituting n = -2 into the above equation, we get:
0a0 + 0a1 - 5a-2 = 0
Solving for a-2, we get:
a-2 = 0
Therefore, the coefficient of x^-2 is 0, which means that the solution cannot be written as a power series in x. We will have to consider a different value of n.
Case 2: n = -6
Substituting n = -6 into the above equation, we get:
0a0 + 0a1 - 5a-6 = 0
Solving for a-6, we get:
FAQ: Find the First 4 Terms of Two Linear Solutions for y"+xy'-5y=0 at x=0
What is the general form of a linear solution for a differential equation?
The general form of a linear solution for a differential equation is y = C1e^(ax) + C2e^(bx), where C1 and C2 are constants and a and b are coefficients.
How do you find the first term of a linear solution for a differential equation?
The first term of a linear solution can be found by substituting x=0 into the general form and solving for y. In this case, the first term would be C1 + C2.
How do you find the second term of a linear solution for a differential equation?
The second term of a linear solution can be found by taking the derivative of the first term and substituting x=0 into the derivative. In this case, the second term would be aC1 + bC2.
What is the significance of the coefficient of the first term in a linear solution?
The coefficient of the first term represents the overall behavior of the solution. A positive coefficient indicates exponential growth, while a negative coefficient indicates exponential decay.
How do you determine the values of the constants in a linear solution?
The constants can be determined by using initial conditions, such as known values of y and y' at a specific point. These conditions can be substituted into the linear solution, resulting in a system of equations that can be solved for the constants.
