Find the first digit after the decimal point
  • MHB
  • Thread starter anemone
  • Tags
    Point
In summary, the first decimal digit after the decimal point in the number $\sqrt{x^2+x+1}$ is 4, if $\large x=2014^{2014^{2014}}$. The original solution provided was correct, but the edited version is more straightforward and accurate as it explains the reasoning behind it. The unedited post was informal and confusing.
anemone
MHB
POTW Director
3,883
115
Determine the first decimal digit after the decimal point in the number $\sqrt{x^2+x+1}$ if $\large x=2014^{2014^{2014}}$
Mathematics news on Phys.org
x is too large $2014^{2014^{2014}}$
so $x^2 + x + 1= (x + 1/2)^2 + 3/4$
= $(x+1/2)^2( 1+ 3/(4(x + 1/2)^2)$
so square root = $(x+1/2) ( 1 + 3/(8(x+1/2)^2) + ...)$
the term $3/(8(x+1/2)^2)$ is extremley small so << .1
so square root is x + 1/2 or 5 is the 1st digit after decimal
Hey kaliprasad, thanks for participating!:) Well done! Your answer is correct... but I think this edited version of the solution isn't quite straightforward than the before edited post.:p
this edited post is more accurate as it defines the reason. As you have made a reference to un edited post I mention the unedited post( exact words I do not remeber so in lines as below) which is highly informal
so $x^2+x+1=(x+1/2)^2+3/4$ and as 3/4 is too small we can igmore so
square root =x + 1/2 so 1st digit after decimal = 5
To find the first decimal digit after the decimal point in the given expression, we can use the fact that the square root of a number is less than or equal to the number itself. Therefore, we can approximate the value of $\sqrt{x^2+x+1}$ by using the value of $x=2014^{2014^{2014}}$.
Using a calculator, we can find that $x$ is a very large number, approximately $2.96 \times 10^{2050}$. This means that the expression $\sqrt{x^2+x+1}$ will also be a very large number, but it will still have a decimal component.
To find the first decimal digit after the decimal point, we can use scientific notation. The value of $x$ can be rewritten as $2.96 \times 10^{2050}$. We can then use the properties of exponents to rewrite the expression as:
$\sqrt{x^2+x+1} = \sqrt{(2.96 \times 10^{2050})^2 + (2.96 \times 10^{2050}) + 1} = \sqrt{8.7616 \times 10^{4100} + 2.96 \times 10^{2050} + 1}$
Using a calculator, we can find that the value inside the square root is approximately $8.7616 \times 10^{4100}$. When we take the square root of this value, we get approximately $2.96 \times 10^{2050}$.
Therefore, the first decimal digit after the decimal point in the given expression is 9. This means that the value of $\sqrt{x^2+x+1}$ is approximately $2.96 \times 10^{2050}.9$.
FAQ: Find the first digit after the decimal point
What does it mean to "find the first digit after the decimal point"?
When dealing with numbers, the decimal point separates the integer (whole number) part from the decimal (fractional) part. The first digit after the decimal point refers to the first number after the decimal point in the decimal portion of a number.
Why is it important to find the first digit after the decimal point?
Knowing the first digit after the decimal point can help with rounding and estimating. It also provides more precision when working with numbers, especially in scientific and mathematical calculations.
How do you find the first digit after the decimal point?
To find the first digit after the decimal point, count from left to right until you reach the first number after the decimal point. This number will be the first digit after the decimal point.
Can the first digit after the decimal point be a zero?
Yes, the first digit after the decimal point can be a zero. However, if there are multiple zeros after the decimal point, only the first non-zero digit should be considered the first digit after the decimal point.
In what situations is finding the first digit after the decimal point useful?
Finding the first digit after the decimal point is useful in various situations, including calculating percentages, converting between units (such as meters to centimeters), and working with significant figures in scientific measurements.
