Find the formula for the inverse function
In summary: The domain of f^-1 is given by -x∈R where f(x) is a real function -x∈R where f^-1(x) is a real functionTherefore, the domain of f^-1 is all real numbers.Now, plot f(x) and f^-1(x) on the same axes and describe the geometric relationship that you can see between them.There is a clear geometric relationship between f(x) and f^-1(x). As x increases, f(x) also increases, but f^-1(x) decreases. Additionally, as x decreases, f(x)
fazal
24
The function f is defined by y=f(x) = 3ln4x 0.01<=x<=1
a)Solve for x in terms of y and hence find the formula for the inverse function f^-1(x)
b)Write down the domain of f^-1
c)Plot f from x =0.01 to x=1 and than plot f^-1 on the same axes but only for domain values of x given by the range of f
d)Describe the geometric relationship that you can see between f and f^-1
plse assist as iam very confused with functions...!
fazal said:
You seem to have missed out an important section.
The rule for the inverse function is given by f^-1(x)
how to make y the subject.
I suggest that i a graph of y = f(x) over and use it to find the range of f ?
are they reflections of each other in the line y = x.??
plse assist to answer
Okay for part (a) we have:
y = 3ln(4x)
Can you solve for x?
for a)
is it this way:
x=1/4e^(y/3)
plse assist is this right?
fazal said:
for a)
is it this way:
x=1/4e^(y/3)
Yes, that is correct. So now you can write the inverse function as
f-1(x) = 1/4exp(x/3)
So, what about the domain of the inverse function?
is the domain from 0.2508<=x<=0.3489
by using 1/4 * e^(0.01/3) and 1/4 * e^(1/3)
plse assist to check
No, that is not correct.
HINT: Think about the range of f(x).
yes the range is from 0.01<=x<=1
therefore i plug into the f^-1 and got
0.2508<=x<=0.3489
0.2508<=x<=0.3489
No, that is the domain for f(x) and why would you want to plug it into f-1(x)?
i can't seem to figure out the domain...plse assist
FAQ: Find the formula for the inverse function
What is an inverse function?
An inverse function is a mathematical concept where the output of a function becomes the input and the input becomes the output. In other words, it is a function that "undoes" the original function.
Why is it important to find the inverse function?
Finding the inverse function can be useful in solving equations and understanding the relationship between variables in a function. It can also help in finding the domain and range of a function.
How do you find the inverse function?
To find the inverse function, you can follow these steps:1. Replace f(x) with y.2. Swap the positions of x and y.3. Solve for y.4. Replace y with f^-1(x).The resulting function is the inverse function.
What is the notation used for inverse functions?
The notation used for inverse functions is f^-1(x), where f is the original function and x is the input variable.
Are all functions invertible?
No, not all functions are invertible. For a function to have an inverse, it must be a one-to-one function, meaning that each input has a unique output. Additionally, the function must pass the horizontal line test, where no horizontal line intersects the graph of the function more than once.
