How do you determine the function of a spring in terms of k?
In summary, the problem asks to find the change in distance, represented by "y", using Hooke's Law. The attempted solution suggests that the change in y is -0.1in, but there is uncertainty in expressing it as a function of k. The question is considered vague and confusing.
drummerscott
*See Attachment*
The problem states to find "y" which I'm assuming is the change in distance from the original point marked "y".
Hooke's Law
I'm pretty sure the change in Y is -0.1in
P=-ky
y=p/-k
y=-0.1
I have no idea how to express things as a function of k (second part of the question)
Thanks!
Maybe it's clear for others, but I find the question totally vague.
Yeah...that is why I'm quite confused. This isn't for physics either, this is "introductory" homework for strength of materials...
FAQ: How do you determine the function of a spring in terms of k?
What is the purpose of finding the function of a spring?
The function of a spring is to understand how a spring behaves under different conditions such as the amount of force applied, the displacement of the spring, and the material it is made of. This information can be used to design and optimize various mechanical systems that use springs.
How do you find the function of a spring?
The function of a spring can be found by conducting experiments and analyzing the resulting data. This involves measuring the displacement of the spring under different amounts of force and plotting the data on a graph. The resulting curve is the function of the spring.
What factors affect the function of a spring?
The function of a spring is affected by various factors such as the material it is made of, the diameter and length of the spring, the number of coils, and the amount of force applied. Other factors such as temperature and the environment can also impact the function of a spring.
Why is it important to know the function of a spring?
Knowing the function of a spring is important for designing and optimizing mechanical systems that use springs. It allows engineers to choose the right type of spring for a specific application and ensure that the spring will behave as expected under different conditions.
Can the function of a spring change over time?
Yes, the function of a spring can change over time due to factors such as wear and tear, changes in temperature, and changes in the material properties. It is important to regularly test and replace springs in mechanical systems to ensure optimal performance.
