Find the general solution of the given PDE
chwala
This is a question set by myself;
##-4u_x+6u_y+10u=e^{x+2y}##
Method of characteristic.
My take;
##ξ=-4x+6y## and ##η=6x+4y##
it follows that,
##52u_ξ +10u=e^{x+2y}##
for the homogenous part; we shall have the general solution;
$$u_h=e^{\frac{-5}{26} ξ} f{η }$$
now we note that
$$e^{x+2y}=e^{\frac{8ξ+η}{26}}$$
that is from solving the simultaneous equation;
##ξ=-4x+6y## and ##η=6x+4y## where ##x=\dfrac{12ξ-18η}{156}## and ##y=\dfrac{3ξ+2η}{26}##
for the inhomogenous part, we shall have;
$$u_p = e^{\frac{-5}{26}ξ}\int \frac{e^{\frac{8ξ+η}{26}}⋅e^{\frac{5}{26}ξ}}{52} dξ$$$$u_p = \frac{e^{\frac{13ξ+η}{26}}⋅e^{\frac{-5}{26}ξ}}{26} $$
$$u(ξ,η)=u_h+u_p=e^{\frac{-5}{26} ξ} \left[ f(η)+\frac{e^{\frac{13ξ+η}{26}}}{26}\right]$$
$$u(x,y)=
e^{\frac{-5}{26} (-4x+6y)} \left[ f(6x+4y)+\frac{1}{26} {e^{\frac{-46x+82y}{26}}}\right]$$your insight is welcome or alternative approach to this problem.
First divide by 2: <br /> -2 u_x + 3u_y + 5u = \tfrac12 e^{x+ 2y}. We want to change to variables (\zeta, \eta) with x_\zeta = -2 and y_\zeta = 3 so that -2u_x + 3u_y = u_xx_\zeta + u_yy_\zeta = u_\zeta. Note that you did the opposite, which was to set <br /> -4 u_x + 6u_y = u_x\xi_x + u_y \xi_y where the right hand side is not the multivariate chain rule for u_\xi.
We therefore set \begin{split}<br /> x &amp;= -2\zeta + a\eta \\ y &amp;= 3\zeta + b\eta \end{split} with a and b chosen such that <br /> x + 2y = 4\zeta + (a + 2b)\eta = 4\zeta. Any choice of b other than b = 0 gives us a 1-1 transformation, but the choice b = -\frac14 gives the convenient \eta = 3x + 2y, and from the above we have \zeta = \frac14(x+2y). The PDE is then reduced to <br /> u_\zeta + 5u = \tfrac12e^{4\zeta} which can be solved by an integrating factor.
@pasmith I'll need to go through your approach...cheers man! Just curious are we going to get same solutions? Your integrating factor seems different just by looking at it...
I get <br /> u = g(\eta&#039;)e^{-5\zeta} + \tfrac{1}{18}e^{4\zeta}.
I think you have made an error: If \xi = -4x + 6y and \eta = 6x + 4y then x = (3\eta - 2\xi)/26,\qquad y = (3\xi + 2\eta)/26. Your result of <br /> x = \frac{12\xi - 18\eta}{156} = \frac{2\xi - 3\eta}{26} is out by a factor of -1, so your calculation of x + 2y is incorrect; you should have <br /> x + 2y = \frac{7\eta + 4\xi}{26}. Note that in terms of my \zeta, \eta&#039; you have \begin{split}<br /> \eta &amp;= 2\eta&#039; \\<br /> \xi &amp;= 26\zeta - \frac{7}{2}\eta&#039;.\end{split} Now solving <br /> u_\xi + \frac{5}{26}u = \frac{1}{52}e^{(7\eta +4\xi)/26} gives \begin{split}<br /> u &amp;= f(\eta)e^{-5\xi/26} + \frac{1}{52}\frac{26}{9}e^{(7\eta+4\xi)/26} \\<br /> &amp;= f(\eta)e^{-5\xi/26} + \frac{1}{18}e^{(7\eta + 4\xi)/26}.\end{split} We agree on the second term, since 4\zeta = x + 2y = \frac{7\eta + 4\xi}{26}. For the first term, we have <br /> f(\eta)e^{-5\xi/26} = \overbrace{f(2\eta&#039;)e^{35\eta&#039;/52}}^{\equiv g(\eta&#039;)}e^{-5\zeta} as required.
I suspect you will agree that the numbers in my solution are simpler than in yours.
