MHB Find the global extrema of this function over the given region
Vishak95
Hi MHB. Can someone help me with this one please?
View attachment 1595I've worked out that the critical points are (0,0) and (2,1). But looking at the boundary x = 0, there seems to be no limit to the minimum value. Also, on the boundary y = 1, the value of f(x,1) = -1.
So, would I be correct in saying that the global maximum value occurs at (2,1) and that there is no global minimum?
Re: Find the global maxima of this function
Before we look at the boundaries, have you used second partials test for relative extrema to determine that nature of the critical points (which you have correctly determined)?
The critical points both appear to be saddle points (the derivative D = -1 for both)
Yes, I get the same result. :D
So now you want to look at the boundaries. What are they?
Great :D
I think the only real boundaries would be x = 0 , and y = 1
Vishak said:
Great :D
Yes, those are the real boundaries. You have already found that:
$$f(0,y)=-y^2$$
and because:
$$\lim_{y\to-\infty}\left(-y^2 \right)=-\infty$$
You correctly conclude that the function has no global minimum. Suppose we choose an arbitrary value for $y$, such as $y=-k$ where $0<k$. Then the function is:
$$f(x,-k)=\left(k^2+k \right)x-k^2$$
What is the limit of this as $$x\to\infty$$?
The limit appears to be going to $$\infty $$. So then I guess that there is no global maximum either?
Yes, I come to the same conclusion. :D
Awesome! Thank you Mark :D
Caution: some people use $\{(x,y)\ |\ 0\leq x,y\leq1\}$ as an abbreviation for $\{(x,y)\ |\ 0\leq x\leq1 \text{ and }0\leq y\leq1\}$. I suspect that is what is intended here. If so, you are being asked for the extreme values of $f(x,y)$ on the unit square. Then the critical point $(2,1)$ is outside the domain $D$, and the boundary consists of four line segments.
That makes much more sense as a problem. :D
