Find the image: F: N * N -> R , F(x) = m^2 + 2n
  • MHB
  • Thread starter KOO
  • Tags
In summary, $F:\mathbb{N}\times\mathbb{N}\rightarrow \mathbb{R}$ is a function where $F(x) = m^2+2n$ for $x=(m,n)$ in the range of integers. If $0\in\mathbb{N}$, then $\mathrm{Im}(F)=\mathbb{N}$. If $0
KOO
F:N*N -> R, F(x) = m^2 + 2n
I think the answer is N. Am I right?
Mathematics news on Phys.org
Based on your title, we have that $F:\mathbb{N}\times\mathbb{N}\rightarrow \mathbb{R}$ ($\mathbb{N}\ast\mathbb{N}$ makes no sense at all) where $F(x) = m^2+2n$ (I assume here that $x=(m,n)$).
Now, depending on who you talk to, $\mathbb{N}$ may or may not include zero (the general consensus from what I've seen is that $0\notin\mathbb{N}$, but there are some professors/authors that include zero in their definition of the natural numbers; hence why I think it's best to clarify this right from the get go); that is, either $\mathbb{N}=\{x\in\mathbb{Z} : x\geq 0\}$ or $\mathbb{N}=\{x\in\mathbb{Z}: x\geq 1\}$.
If $0\in\mathbb{N}$, then $\mathrm{Im}(F)=\mathbb{N}$. If $0\notin\mathbb{N}$, then $\mathrm{Im}(F) = \mathbb{N}\backslash\{1,2,4\}$ since there aren't pairs $(m,n)\in\mathbb{N}\times\mathbb{N}$ such that $m^2+2n=1$, $m^2+2n=2$, or $m^2+2n=4$.
(In $\mathrm{Im}(F)$, note that all the positive odd numbers greater than or equal to 3 are generated by pairs of the form $(1,n)$ for $n\in\mathbb{N}$ since $1^2+2n=2n+1$, and all positive even numbers greater than or equal to 6 are generated by pairs of the form $(2,m)$ for $m\in\mathbb{N}$ since $2^2+2m = 2(m+2)$; this is why I can claim that $F(\mathbb{N}\times\mathbb{N}) = \mathbb{N}\backslash\{1,2,4\}$ for $0\notin\mathbb{N}$.)
I hope this makes sense!
Actually I had this question on a test and you're right x=(m,n) and we're told N does not include 0.
Anyways what does \ mean?
Ah, that's one notation for set difference. I could have also written it as $\mathbb{N}-\{1,2,4\}$.
I just wanted to let you know that I moved this topic from Calculus to Pre-Calculus (this is a better fit) and copied the problem from the title into the body of the first post. It's okay to put the problem in the title when it is short, but we ask that it also be included in the post as well for clarity. :D
FAQ: Find the image: F: N * N -> R , F(x) = m^2 + 2n
1. What does the function F(x) = m^2 + 2n represent?
The function F(x) represents a relationship between two variables, m and n. It takes in two inputs, m and n, and produces an output based on the given formula. In this case, the output is the square of m plus twice the value of n.
2. How do you solve for the value of m or n in the function F(x) = m^2 + 2n?
To solve for the value of m or n, you need to have at least one known variable and the output of the function. You can substitute the known values into the formula and then solve for the unknown variable using algebraic manipulation.
3. Is the function F(x) = m^2 + 2n a linear or non-linear function?
The function F(x) is a non-linear function because it contains a squared term, m^2. In a linear function, the highest power of the variable is 1.
4. What is the domain and range of the function F(x) = m^2 + 2n?
The domain of the function F(x) is all real numbers, as there are no restrictions on the values of m and n. The range of the function depends on the values of m and n, but it will always be a real number since the output of the function is squared and then added to another number.
5. How can the function F(x) = m^2 + 2n be applied in real-life situations?
The function F(x) can be used to represent various relationships in real-life situations. For example, it can represent the area of a square with side length m and the perimeter of a rectangle with length m and width n. It can also represent the amount of energy produced by a wind turbine with blades of length m and n. The specific application depends on the context of the given problem.
