Find the increase in the length of the rod
In summary, the temperature at x = 0 and x = L/2 is the same, but at x = L, the temperature is maximum. The coefficient of linear expansion of the rod is α.
utkarshakash
A metal rod of length L at temperature of 0°C is not uniformly heated such that the temperature is given by the distance x along its length measured from one end when:
[itex]T(x) = T_0 \sin (\pi x/L) [/itex]
Accordingly, points at x = 0 and x = L are also zero temperature, whereas at x = L/2, where the argument of sine function is π/2, the temperature have the maximum value T0. The coefficient of linear expansion of the rod is α. Find the increase in the length of the rod in function of α and T0.
Let us consider a differential element dx at a distance x from one end of the rod.
[itex]Δ(dx) = dx \alpha dT \\
ΔL = \alpha T_0 \displaystyle \int_0^L \cos \left( \dfrac{\pi x}{L} \right) dx [/itex]
But the above equation gives me 0! :confused:
I know something's going wrong here.
[/itex]
Careful. That should be ΔT, not dT. The temperature difference is a finite function of x, not a differential. (And if it's with respect to 0°, then ΔT = T.)
Thanks!
What is the answer ?
[itex]2L \alpha T_0 / \pi [/itex]
Could you please show how you got this answer.
Sure.
Let's consider a differential element dx at a distance x from one end of the rod.
[itex]Δ(dx) = dx \alpha (t(0) - t(x)) \\
=- \alpha T_0 \sin \dfrac{\pi x}{L} dx \\
[/itex]
Integrating both sides
[itex] ΔL = \dfrac{- L \alpha T_0}{\pi} \left( \cos \dfrac{\pi x}{L} \right)_0^L [/itex]
Substitute the values to get the answer.
Likes 1 person
utkarshakash said:
Sure.
[/itex]
Thanks a lot :)
Related to Find the increase in the length of the rod
What exactly is meant by "increase in the length of the rod"?
"Increase in the length of the rod" refers to the change in the physical size of a rod, typically measured in units such as inches or centimeters.
How can the increase in length of a rod be determined?
The increase in the length of a rod can be determined by measuring the initial length of the rod and then measuring the final length after it has undergone some sort of change, such as being heated or stretched.
What factors can affect the increase in length of a rod?
The increase in length of a rod can be affected by various factors such as the material of the rod, the amount of force or temperature applied, and the duration of the change.
What are some common methods for finding the increase in length of a rod?
Some common methods for finding the increase in length of a rod include using a ruler or caliper to measure the length before and after the change, using a strain gauge to measure the strain on the rod, or using mathematical equations based on the material properties of the rod.
Why is it important to find the increase in length of a rod?
Finding the increase in length of a rod is important in various scientific and engineering applications, such as understanding the behavior of materials under different conditions, designing structures and machines, and predicting the performance of materials in different environments.
