MHB Find the integral for pumping water out of a cone-shaped tank.
  • Thread starter Thread starter shamieh
    Integral
To set up the integral for the work required to pump water out of an inverted cone-shaped tank, first establish the relationship between the height and radius using similar triangles, yielding r = h/10. The area of a cross-sectional disk at height h is given by πr², which simplifies to πh²/100. The volume of a thin layer of water is then expressed as (π/100)h²dh, and its weight is (πδ/100)h²dh, where δ is the density of water. The work done to lift this weight from height h to the top of the tank (10m) is (πδ/100)h²(10 - h)dh. The integral to find the total work is set up by integrating this expression from h = 0 to h = 8.
shamieh
All I need to do for this problem is set up the integral...Can someone tell me how to do that?
A tank has the shape of an inverted circular cone with height 10m and base with radius 1m. The tank is filled with water to a height of 8 m . Find the work required to empty the tank by pumping all of the water over the top.NOTE: I just need to set up the integral, I don't actually have to calculate the problem.
Here are two threads that deal with this kind of problem:
http://mathhelpboards.com/questions-other-sites-52/kendra-ns-question-yahoo-answers-regarding-work-done-empty-conical-tank-4661.html
http://mathhelpboards.com/questions-other-sites-52/domenics-question-yahoo-answers-regarding-computing-work-empty-tank-8541.html
From the side the cone looks like a triangle and we can use similar triangles. With height h, the distance from the center of the cone to the side, r, we have r/h= 1/10 so that r= h/10. The area of the disk at that height is \pi r^2= \pi h^2/100 and the volume of a thin 'layer of water', with thickness dh is \frac{\pi}{100}h^2 dh. Taking \delta to be the density of water, it's weight is \frac{\pi\delta}{100}h^2dh. Lifting that from height h to height 10m requires \frac{\pi\delta}{100}h^2(10- h)dh Joules of work. Integrate that from h= 0 to h= 8.
