Find the integral of ln(x)/sqrt(x) as x is between 0 and 1
  • Thread starter suspenc3
  • Tags
    Integral
In summary, the conversation discusses the integral \int_0^1 \frac{lnx}{\sqrt x} dx and its divergence. The use of substitution is suggested, but it is determined that the integral is divergent due to the limit approaching infinity. The concept of finding the answer or not in an improper integral is also mentioned.
suspenc3
402
Hi I am trying to figure out the following..Ive tried substitutions but can't find any that work:
[tex]\int_0^1 \frac{lnx}{ \sqrt x}dx[/tex]
HA @ 0 so
[tex]\int_0^1 \frac{lnx}{ \sqrt x} dx[/tex]
[tex]\lim_{t\rightarrow 0^+} \int_t^1 \frac{lnx}{\sqrt x}dx[/tex]
Try the substitution u=sqrt(x).
so...2du=1/root(x)dx.. it becomes just ln(u^2)?
if this is right I end up with
[tex]\lim_{t\rightarrow 0^+} 2 - \frac{s\sqrt t}{t}[/tex]
so would this be divergent?
I don't know what s is there, but yes, this is divergent. Another way to find this is to note that this function is less than ln(x), whose integral diverges to negative infinity on this interval.
ok, the s should be a two...so basically if the integral ever has [tex] \frac{a}{0}[/tex]...then it is called divergent?..or whenever an answer cannot be found..it is divergent?
This integral is divergent because the limit you mention in your first post is infinity. "if the integral ever has a/0" isn't precise enough an expression for me to say anything meaningful about. In general, for improper integrals like this one, you have to take a limit as you approach vertical asymptopes or as [itex]x \rightarrow \pm \infty[/tex]. If the result after taking all these limits is infinity, the integral is said to diverge. Whether you can find the answer or not is your problem, not the integral's.
FAQ: Find the integral of ln(x)/sqrt(x) as x is between 0 and 1
What is the integral of ln(x)/sqrt(x) as x is between 0 and 1?
The integral of ln(x)/sqrt(x) as x is between 0 and 1 is equal to -4.
How do you solve for the integral of ln(x)/sqrt(x) as x is between 0 and 1?
To solve for the integral of ln(x)/sqrt(x) as x is between 0 and 1, you can use the substitution method or integration by parts.
Is it possible to find the integral of ln(x)/sqrt(x) as x is between 0 and 1 without using calculus?
No, it is not possible to find the integral of ln(x)/sqrt(x) as x is between 0 and 1 without using calculus. Integration is a fundamental concept in calculus and is necessary for finding the area under a curve.
Why is the integral of ln(x)/sqrt(x) as x is between 0 and 1 a negative value?
The integral of ln(x)/sqrt(x) as x is between 0 and 1 is a negative value because the function is negative in the given interval. This means that the area under the curve is below the x-axis, resulting in a negative value.
What is the significance of finding the integral of ln(x)/sqrt(x) as x is between 0 and 1?
Finding the integral of ln(x)/sqrt(x) as x is between 0 and 1 allows us to calculate the area under the curve and understand the behavior of the function in the given interval. It also helps in solving various mathematical and scientific problems that involve this particular function.
