Find the Inverse of a Vector: Solve for x in Terms of b
In summary, the conversation is about trying to solve an equation involving finding the minimum of a function with two norms, where the system is overdetermined. The individual has already found the solution for the first norm, but is struggling with finding the solution for the second norm. They have differentiated the second norm with respect to the variables and set it to zero, but are now stuck. They are looking for help in finding a closed form solution for the minimum of the second norm.
OhMyMarkov
83
Hello Everyone!
I've been trying to solve an equation and got to this place: $\sum _{j=1} ^K (x_j - b_j) = 0$ which gives $e^T x = e^T b$. Now I need to solve for $x$ i.e. find $x$ in terms of the b. How can I do that?
Thank you for the help!
OhMyMarkov said:
Hello Everyone!
Can we have some more context, or perhaps the original problem?
CB
Definitely,
The original problem is to find the minimum of the following function: $T(x) = ||y-Ax||^2 + ||x-b||^2$ where the system y = Ax is overdetermined. Of course we already know the closed form solution of the first norm (linear least squares). My question was regarding the second norm. What I want to do is to try to find a closed form solution for the minimum of the second norm, and add the two solutions up. What I did was, similar to the approach of finding the linear least squares solution, differentiate the second norm with respect to $x_j$s and set to zero. I got what is there in my first post, and now I'm stuck there.
Thank you.
FAQ: Find the Inverse of a Vector: Solve for x in Terms of b
What is a vector?
A vector is a mathematical object that has both magnitude (or size) and direction. It is represented by an arrow, with the length of the arrow corresponding to the magnitude and the direction of the arrow indicating the direction.
Why do we need to find the inverse of a vector?
Finding the inverse of a vector allows us to solve for the value of x in terms of b. This can be useful in solving equations or problems involving vectors, such as finding the components of a vector or determining the angle between two vectors.
How do you find the inverse of a vector?
To find the inverse of a vector, we use the concept of vector addition and subtraction. We can manipulate the given vector and its inverse to obtain a new vector with a magnitude of 0, which is known as the zero vector. The value of x can then be solved by setting the components of the zero vector equal to the given vector and its inverse.
Can the inverse of a vector be negative?
Yes, the inverse of a vector can be negative. The direction of the inverse vector will be opposite to the direction of the given vector, but the magnitude will remain the same. This is because the inverse vector is obtained by negating the components of the given vector.
What are some practical applications of finding the inverse of a vector?
Finding the inverse of a vector is commonly used in physics and engineering, particularly in problems involving forces and motion. It is also useful in computer graphics and game development, where vectors are used to represent movement and position in 3D space.
