Find the inverse of this function. .
In summary, the original function is \(f(x) = \dfrac{1 - \sqrt{x}}{1 + \sqrt{x}}\) and the inverse function is \(f^{-1}(x) = \dfrac{(x - 1)^2}{(x + 1)^2}\) with the domain restricted to \(-1 < x \leq 1\). The domain of the inverse reflects the range of the original function. The values of \(x\) and \(y\) were not interchanged in the solution.
checkitagain
138
[tex]f(x) \ = \ \dfrac{1 - \sqrt{x}}{1 + \sqrt{x}}[/tex]
Mathematics news on Phys.org
Hi checkittwice,
Let, \(y = \dfrac{1 - \sqrt{x}}{1 + \sqrt{x}}\)
\[y(1-x)=(1-\sqrt{x})^2\]
\[y(1-x)=1-2\sqrt{x}+x\]
\[(y-yx-x-1)^2=4x\]
\[((y-1)-x(y+1))^2=4x\]
\[(y+1)^{2}x^2-2(y-1)(y+1)x+(y-1)^2=4x\]
\[(y+1)^{2}x^2-\left\{2(y-1)(y+1)+4\right\}x+(y-1)^2=0\]
\[x=\frac{\left\{2(y-1)(y+1)+4\right\}\pm\sqrt{\left\{2(y-1)(y+1)+4\right\}^2-4(y+1)^{2}(y-1)^2}}{2(y+1)^{2}}\]
\[x=\frac{\left\{2(y-1)(y+1)+4\right\}\pm\sqrt{16+16(y-1)(y+1)}}{2(y+1)^{2}}\]
\[x=\frac{\left\{2(y-1)(y+1)+4\right\}\pm 4|y|}{2(y+1)^{2}}\]
\[x=\frac{y^2\pm 2|y|+1}{(y+1)^{2}}\]
If we use the positive sign, \(x=1\) whenever \(y\geq 0\). Similarly if we use the negative sign, \(x=1\) whenever \(y\leq 0\). Both of these are not true considering our original equation. Therefore the only possibility is to use the positive sign when \(y<0\) and the negative sign when \(y\geq 0\). This gives us,
\[x = \frac{(y-1)^2}{(y+1)^{2}}\]
Sudharaka said:
\[x = \frac{(y-1)^2}{(y+1)^{2}}\] ? ? ?
Sudharaka,
here are two observations/prompts:
1) Nowhere in your work did you ever interchange x any y.
2) Suppose you were to interchange x and y to get
[tex]y \ = \ \dfrac{(x - 1)^2}{(x + 1)^2}[/tex]Would that be a one-to-one function?
Or, would you have to restrict the domain (and state it as such)
to get the correct inverse?
The problem is still open.
checkittwice said:
Sudharaka,
Hi checkittwice,
In my final answer \(y\) is the independent variable and \(x\) is the dependent variable. I thought it would be understood and did not interchange \(x\) and \(y\). I hope this is the thing that you mentioned in your first statement.
And of course I forgot to mention about the domain of the inverse in my first post. In the original function, \(x\geq 0\). Therefore in the inverse function; \(\displaystyle y \ = \ \dfrac{(x - 1)^2}{(x + 1)^2}\) we have to make \(y\geq 0\). For that \(x\geq 1\). So the inverse function would be,
\[\displaystyle y \ = \ \dfrac{(x - 1)^2}{(x + 1)^2}\mbox{ where }x\geq 1\]
We can express x through y more simply:
[tex]y(1+\sqrt{x})=1-\sqrt{x}[/tex]
[tex]y+y\sqrt{x}=1-\sqrt{x}[/tex]
[tex]\sqrt{x}(1+y)=1-y[/tex]
[tex]\sqrt{x}=\frac{1-y}{1+y}[/tex]
[tex]x=\left(\frac{1-y}{1+y}\right)^2[/tex]
Also, one can check for the original function that when [tex]x\in[0,\infty)[/tex], one has [tex]-1<y\le 1[/tex]. The latter inequality determines the domain of the inverse function.
Sudharaka said:
Hi checkittwice,
>The value of [tex]f^{-1}(x) [/tex]depends on what x equals.
>You can't go by what you "understood" if the problem isn't finished as typed
by you.
>For example, if I were to ask for the inverse of y = f(x) = 0.5x, someone would
not answer with 2y = x. They would answer with [tex]f^{-1}(x) \ = \ 2x.[/tex]
>My first statement of my second post in this thread is redundant, because
the inverse will be of the form [tex]f^{-1}(x)[/tex] = an expression in terms of x.I hope this is the thing that you mentioned in your first statement.
And as alluded to by Evgeny.Makarov, the domain of the desired
inverse will reflect the range of the original function.
So, to clear things up, the inverse is:[tex]f^{-1}(x) \ = \ \ \dfrac{(x - 1)^2}{(x + 1)^2}, \ \ -1< x \le 1.[/tex]
FAQ: Find the inverse of this function. .
1. What is the inverse of a function?
A function's inverse is a new function that "undoes" the original function. It reverses the input and output values, so that the input of the original function becomes the output of the inverse function, and vice versa.
2. How can I find the inverse of a function?
To find the inverse of a function, you can follow these steps:
1. Replace the function's name with "y".
2. Swap the x and y variables in the equation.
3. Solve the new equation for y. This will be the inverse function!
3. Are all functions invertible?
No, not all functions are invertible. For a function to have an inverse, it must pass the horizontal line test, meaning that no horizontal line can intersect the graph of the function more than once. If a function does not pass this test, it does not have an inverse.
4. Can a function have more than one inverse?
No, a function can only have one inverse. This is because the inverse function must satisfy the definition of a function, which states that each input can only have one output.
5. Why is finding the inverse of a function important?
Finding the inverse of a function is important because it allows us to "undo" a function and find the original input value given an output value. This is useful in many real-life scenarios, such as finding the original price of an item after a discount, or finding the initial amount of a substance after it has undergone a chemical reaction.
