Find the kinetic energy stored in the flywheel
In summary, the conversation discusses a problem involving a car powered by a rotating flywheel. The flywheel has a radius of 1.00 m and a mass of 425 kg, and is attached to an electric motor to bring its rotational speed up to 4000 rev/min. The question asks for the kinetic energy stored in the flywheel and the length of time it could run as a 15.0-hp motor. The incorrect use of the moment of inertia for a circular hoop was identified and the correct equation, I=(1/2)MR^2, was suggested. This led to the successful solution of the problem.
persephone
A car is designed to get its energy from a rotating flywheel (solid disk) with a radius of 1.00 m and a mass of 425 kg. Before a trip, the flywheel is attached to an electric motor, which brings the flywheel's rotational speed up to 4000 rev/min.
(a) Find the kinetic energy stored in the flywheel.
(b) If the flywheel is to supply energy to the car as would a 15.0-hp motor, find the length of time the car could run before the flywheel would have to be brought back up to speed.
KE=(1/2)Iw^2
where I=Mr^2
P=KE/t
First I used the equation to find the moment of inertia: I=(425kg)(1)^2=425
I know that the angular velocity is 4000 rev/min, so I converted that to 418.879 rad/s
Then I plugged that into the the equation for KE: 1/2(425)(418.879 rad/s)^2 =3.73e7
This was wrong...
For part b, I used the equation relating power to kinetic energy, so I converted 15 hp to 11185.5 Watt
So, 3.73e7/11185.5 = t = 3334.67s
Also wrong..
Is there something I'm missing here? I can't figure out for the life of me what I'm doing wrong.
At first glance, I noticed that you are using the wrong moment of inertia.
You are using the moment of inertia for a circular hoop, not a solid disc. The moment of inertia for a disc is:
[tex]I=\frac{1}{2}MR^2[/tex]
Try working the problem with this moment of inertia and see if it helps.
ah ha! that equation worked! I'm a total newb at physics so I wasn't aware there was a separate equation for the moment of inertia for a disc
Thank you so much!
No problem. I'm glad to be of help! :smile:
FAQ: Find the kinetic energy stored in the flywheel
What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion.
What is a flywheel?
A flywheel is a mechanical device used to store rotational energy.
How do you calculate the kinetic energy stored in a flywheel?
The formula for calculating the kinetic energy of a flywheel is KE = 1/2 * I * ω^2, where I is the moment of inertia and ω is the angular velocity.
What factors affect the kinetic energy stored in a flywheel?
The kinetic energy stored in a flywheel is affected by its mass, shape, and angular velocity.
What are some real-life applications of flywheels and their kinetic energy?
Flywheels are commonly used in vehicles, such as cars and trains, to store energy and provide a smoother ride. They are also used in energy storage systems to store energy from renewable sources for later use.
