Find the Largest Area of Triangle
In summary, the largest area that the triangle ABC can have is 820, which can be obtained by either using a geometric approach or by applying AM-GM inequality.
anemone
MHB
POTW Director
3,883
115
Triangle ABC has \(\displaystyle AB=9\) and \(\displaystyle BC:AC=40:41\). What's the largest area that this triangle can have?
Mathematics news on Phys.org
My solution:
Let:
\(\displaystyle \overline{BC}=a\)
\(\displaystyle \overline{AC}=b\)
and we are told:
\(\displaystyle b=\frac{41}{40}a\)
Using Heron's formula, the area of the triangle as a function of $a$ is:
\(\displaystyle A(a)=\frac{9\sqrt{-81a^4+10499200a^2-207360000}}{6400}\)
The area is maximized where the radicand is maximized, hence:
\(\displaystyle \frac{d}{da}\left(-81a^4+10499200a^2-207360000 \right)=4a\left(5249600-81a^2 \right)=0\)
Discarding $a=0$, and taking the positive root, we find the critical value is:
\(\displaystyle a=\frac{40\sqrt{3281}}{9}\)
We know this is a maximum since the radicand is a quartic with a negative leading coefficient.
Thus, the maximum area is:
\(\displaystyle A_{\max}=A\left(\frac{40\sqrt{3281}}{9} \right)=820\)
Here is a geometric way to get the same answer.
[sp]
If the ratio $BC:AC$ is $40:41$ then $C$ must lie on an Apollonius circle with diameter $PQ$, where $P,Q$ lie on the line $AB$, with the ratios $BP:AP$ and $BQ:AQ$ both equal to $40:41$. Since $AB=9$, we must have $AP = 41/9$, $PB = 40/9$ and $BQ = 360.$ Thus the radius of the circle is $\frac12\bigl(360 + \frac{40}9\bigr) = 1640/9.$ The area of the triangle is obviously greatest when $C$ is at its maximum height above the line $AB$, in other words when it is directly above the centre of the circle. The height $OC$ is then the radius of the circle, and the area of the triangle is $\frac12AB*OC = \dfrac92\dfrac{1640}9 = 820.$​
[/sp]
Hi MarkFL and Opalg,
Thank you so much for participating in this problem.
Opalg, your solution is definitely an ingenious approach and I have talked to MarkFL and we don't think we would have thought of that geometric approach to solve this problem!:cool:
Not so quick...where is your solution? (Clapping)
My solution:
We first let the three sides of the triangle ABC be \(\displaystyle 9,\;40k,\;41k\).
By using the Heron's formula to find the area of the triangle ABC\(\displaystyle (A_{\text{triangle ABC}})\), we see that we have
\(\displaystyle A_{\text{triangle ABC}}=\sqrt{\left( \frac{81k+9}{2}\right)\left(\frac{81k+9}{2}-9\right)\left(\frac{81k+9}{2}-40k\right)\left(\frac{81k+9}{2}-41k\right)}\)
\(\displaystyle \;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;=\frac{3}{4} \sqrt{-81\left(k^4-\frac{(81^2+1)k^2}{81}+1\right)}\)
And if we let \(\displaystyle k^2=x\), the equation above becomes
\(\displaystyle \;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;=\frac{3}{4} \sqrt{-81\left(x^2-\frac{(81^2+1)x}{81}+1\right)}\)
By completing the square of the radicand, we obtain
\(\displaystyle \;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;=\frac{3}{4} \sqrt{-81\left(x-\frac{3281}{81}\right)^2+\frac{3281^2}{81}-81}\)
Hence,
\(\displaystyle A_{\text{maximum}}=\frac{3}{4} \sqrt{\frac{3281^2}{81}-81}=820\)
Alternatively, we could approach this problem by applying AM-GM inequality if we write the radicand a bit differently.
\(\displaystyle \;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;= \frac{1}{4} \sqrt{ 9(9k+1)(9k-1)(9+k)(9-k)}\)
\(\displaystyle \;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;= \frac{1}{4} \sqrt{ (9k+1)(9k-1)(81+9k)(81-9k)}\)
\(\displaystyle \;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;= \frac{1}{4} \sqrt{ (81k^2-1)(81^2-81k^2)}\)
By applying AM-GM inequality to these two terms \(\displaystyle 81k^2-1\) and \(\displaystyle 81^2-81k^2\) gives
\(\displaystyle \frac{81k^2-1+81^2-81k^2}{2}\ge \sqrt{(81k^2-1)(81^2-81k^2)}\)
\(\displaystyle \sqrt{(81k^2-1)(81^2-81k^2)} \le \frac{81^2-1}{2}\)
Now, we can conclude that
\(\displaystyle A_{\text{maximum}}=\frac{1}{4}\left( \frac{81^2-1}{2}\right)=820\)
FAQ: Find the Largest Area of Triangle
What is the formula for finding the largest area of a triangle?
The formula for finding the largest area of a triangle is: A = 1/2 * base * height, where A represents the area, the base is the length of the triangle's base, and the height is the perpendicular distance from the base to the opposite vertex.
How do I determine the base and height of a triangle?
The base and height of a triangle can be determined by measuring the length of the base and the perpendicular distance from the base to the opposite vertex using a ruler or measuring tape.
Can the largest area of a triangle be found with any given three side lengths?
No, the largest area of a triangle can only be found if the triangle satisfies the inequality theorem, which states that the sum of any two sides of a triangle must be greater than the third side.
Is there a maximum or minimum area for a triangle?
Yes, there is a minimum area of 0 for a triangle, which would occur if the triangle has a base or height of 0. There is no maximum area for a triangle, as the area can be infinitely large depending on the length of the base and height.
Can the largest area of a triangle be found using different units of measurement?
Yes, the largest area of a triangle can be found using any unit of measurement as long as the base and height are measured using the same unit.
