Find the last five digits of T_2014
  • MHB
  • Thread starter anemone
In summary, we can find the last five digits of $T_{2014}$ by using the given sequence $T_n$ and solving for the equation $\displaystyle T_{2\ n + 1} = n^{2} + n + 1$. This leads to the answer of $\displaystyle T_{2014} = 1007^{2} + 1 = 1014050$.
anemone
MHB
POTW Director
3,883
115
Let $T_n$ be a sequence such that $T_1=1$ and $T_{n+1}=\lfloor T_n+\sqrt{T_n}+0.5 \rfloor$.
Find the last five digits of $T_{2014}$.
Mathematics news on Phys.org
[sp]With some comfortable steps You find that is...
$\displaystyle T_{2\ n } = T_{2\ n + 1} - n = n^{2} + 1$
...so that is $\displaystyle T_{2014} = 1007^{2} + 1 = 1014050$...[/sp]
Kind regards$\chi$ $\sigma$
Thanks chisigma for participating and the answer you have is correct! Well done!:)
I am thinking it would be best if you can show us how you arrived at the equation $\displaystyle T_{2\ n + 1} = n^{2} + n + 1$...(Sun)
Let suppose at first don't to consider the floor function and the constant .5 and also suppose that the sequence starts with the index n=0, so that we work on the difference equation...
$\displaystyle \Delta{n}= T_{n+1} - T_{n} = \sqrt{T_{n}}\ (1)$
The (1) can be approximated with the ODE...
$\displaystyle y^{\ '} = \sqrt{y}\ (2)$
...the solution of which is...
$\displaystyle y = \frac{x^{2} + 2\ c\ x + c^{2}}{4}\ (3)$Now setting x=2 n and with a proper choise of c we arive to write...
$T_{2\ n} \sim n^{2} + n + 1\ (4)$
Of corse I don't say that all that is 'rigorous' at cent per cent...
Kind regards
$\chi$ $\sigma$
$T_1=1$
$T_2=T_{2\times 1}=\lfloor 1+\sqrt1+0.5 \rfloor=2=1^2+1$.
$T_3=T_{2\times 1+1}=\lfloor 2+\sqrt2+0.5 \rfloor=3=1^2+1+1$.
$T_4=T_{2\times 2}=\lfloor 3+\sqrt 3+0.5 \rfloor=5=2^2+1$.
$T_5=T_{2\times 2+1}=\lfloor 5+\sqrt5+0.5 \rfloor=7=2^2+2+1$.
$T_6=T_{2\times 3}=\lfloor 7+\sqrt7+0.5 \rfloor=10=3^2+1$.
$T_7=T_{2\times 3+1}=\lfloor 10+\sqrt{10}+0.5 \rfloor=13=3^2+3+1$.
from above we may suggest:
$T_{2n}=n^2+1$.---(1)
$T_{2n+1}=n^2+n+1$----(2).
(here n=1,2,3,4,5,-------)
$\therefore T_{2014}=1007^2+1=1014049+1=1014050$
the proof of(1) and (2)we can use the method of induction
FAQ: Find the last five digits of T_2014
How do you find the last five digits of T_2014?
To find the last five digits of T_2014, you can use a mathematical formula or algorithm specifically designed for this purpose. Alternatively, you can also use a computer program or calculator to calculate the value.
What is the significance of finding the last five digits of T_2014?
The last five digits of T_2014 can provide important information about the value itself and its properties. For example, it can help identify patterns or relationships between T_2014 and other numbers, or it can be used to verify the accuracy of calculations involving T_2014.
Can the last five digits of T_2014 be predicted or guessed?
No, it is not possible to predict or guess the last five digits of T_2014 without using a specific formula or algorithm. The value of T_2014 is determined by a complex mathematical process and cannot be easily guessed or predicted.
Are there any real-world applications for finding the last five digits of T_2014?
Yes, there are several real-world applications for finding the last five digits of T_2014, such as in cryptography, data encryption, and data compression. It can also be used in various scientific and engineering calculations that involve large numbers.
Is there a shortcut or simpler method for finding the last five digits of T_2014?
No, there is no shortcut or simpler method for finding the last five digits of T_2014. However, using a computer program or calculator can make the process faster and more efficient compared to calculating it manually using a formula or algorithm.
