Find the latent heat of fusion of ice
In summary, the problem involves finding the latent heat of fusion of ice by determining the amount of heat contained by the initial water and accounting for the additional heating required to raise the water temperature after the ice melts. The equation mc(delta)t=mc(delta)t may be used, but it is important to consider the numbers being plugged in.
soccerawesome
1. I need to find the latent heat of fusion of ice. The problem scenario is that i have a cup and fill it 1/3 full with water. I then take a cube of ice and put it in the cup. then the cube of ice melts
mass of the cup=.24g
mass of the cup when filled 1/3 with water=71.16g
initial temperature of water in cup=21 celsius
temperature of water after melt=4 celsius
mass after the ice melts-98.88g
2. It has something to do with mc(delta)t
maybe mc(delta)t=mc(delta)t
3. I just don't know where the numbers are plugged in. Please help
Welcome to PF.
You are on the right track.
First of all figure how much heat is contained by the initial water alone. From net mass of water (less the cup) times the temperature drop of that water then would maybe give you what you want, except that after the ice melts you have the additional heating that went into raising the water in the ice up to 4°.
So figure how to account for that.
What's left over must be what was required to melt the ice.
The latent heat of fusion of ice is the amount of energy required to change a substance from a solid to a liquid state without changing its temperature. In this scenario, the ice cube is melting in the cup of water, so the latent heat of fusion of ice is the energy that is being transferred from the water to the ice to cause it to melt.
To calculate the latent heat of fusion of ice, we can use the formula Q = m L, where Q is the heat energy, m is the mass of the substance, and L is the latent heat of fusion. In this case, the mass of the ice cube is 71.16g - 98.88g = 27.72g. We also know that the initial temperature of the water is 21 degrees Celsius and the final temperature is 4 degrees Celsius. We can use the specific heat capacity of water, which is 4.186 J/g°C, to calculate the heat energy required to change the temperature of the water from 21°C to 4°C. This can be done using the formula Q = mc(delta)t, where c is the specific heat capacity of water and (delta)t is the change in temperature.
So, the heat energy required to change the temperature of the water is Q = (71.16g)(4.186 J/g°C)(4°C - 21°C) = -582.7 J. The negative sign indicates that the water is losing heat energy.
Next, we can use the formula Q = m L to calculate the latent heat of fusion of ice. We know that Q is -582.7 J, m is 27.72g, and we need to solve for L. Rearranging the formula, we get L = Q/m. So, the latent heat of fusion of ice is -582.7 J / 27.72g = -21.0 J/g. The negative sign indicates that the ice is gaining heat energy.
Therefore, the latent heat of fusion of ice in this scenario is -21.0 J/g. This means that for every gram of ice that melts, 21.0 J of heat energy is transferred from the water to the ice.
FAQ: Find the latent heat of fusion of ice
What is latent heat of fusion?
Latent heat of fusion is the amount of energy required to change a substance from solid to liquid at a constant temperature and pressure.
Why is it important to find the latent heat of fusion of ice?
The latent heat of fusion of ice is important to know because it helps us understand the behavior of water and its phase changes. It also has practical applications in fields such as refrigeration and climate science.
How is the latent heat of fusion of ice measured?
The latent heat of fusion of ice is typically measured using a calorimeter, which is a device that measures the amount of heat absorbed or released during a phase change. In this case, the amount of heat absorbed as ice melts into water is measured.
What factors can affect the latent heat of fusion of ice?
The latent heat of fusion of ice can be affected by factors such as pressure, impurities in the ice, and the rate at which the ice is melting. Additionally, the latent heat of fusion can vary slightly depending on the isotopic composition of the water.
How does the latent heat of fusion of ice compare to the latent heat of vaporization of water?
The latent heat of fusion of ice is significantly lower than the latent heat of vaporization of water. This is because the bonds between water molecules are weaker in the solid state, making it easier for them to break and change into a liquid state. The latent heat of vaporization is much higher because it requires breaking strong intermolecular bonds to change from liquid to gas.
