Find the length of the curve from 0 to 1
In summary, the problem is to find the length of the curve r(t) = <4t, t^(2) + 1/6(t)^(3)> from 0≤t≤1 using the equation L(t) = ∫a to b √(dx/dt)^(2) +(dy/dt)^(2) + (dz/dt)^(2))dt. After taking the derivative and finding the magnitude, the integral becomes ∫ 0 to 1 √(16+4t^(2) + 1/324(t)^(4))dt. However, there are some errors in the (dy/dt)^2 term and correcting them only makes the integrand
jorgegalvan93
find the length of the curve… r(t) = <4t, t^(2) + 1/6(t)^(3)> from 0≤t≤1
After taking the derivative of all components of the curve and finding the magnitude…
And I can't manage to simplify any further.
I tried, doing ∫ 0 to 1 √(t)^(4) + 1296t^(2) + 5184
I don't know how to go any further in simplifying and pulling some t's out of the radical.
I know, it's some algebra, but I have no idea how to go about this from here.
The seem to be a few errors in the (dy/dt)2 term.
OTOH, corecting them makes the integrand look even worse.
FAQ: Find the length of the curve from 0 to 1
What does "finding the length of the curve" mean?
When we talk about finding the length of a curve, we are referring to calculating the distance between two points on a curve. This is often done by using a mathematical formula or by approximating the curve with straight lines.
What is the importance of finding the length of a curve?
Finding the length of a curve is important in various fields of science and engineering, such as physics, calculus, and geometry. It allows us to accurately measure and analyze the shape and size of curves, which can be used to solve real-world problems and make predictions.
How is the length of a curve calculated?
The length of a curve can be calculated using various methods, depending on the complexity of the curve. Some common methods include using the arc length formula, the Pythagorean theorem, or numerical integration.
Can the length of a curve be infinite?
Yes, the length of a curve can be infinite if the curve is a fractal or has an infinite number of points. However, in most cases, we are able to find a finite length for a curve by using mathematical techniques.
How does the length of a curve from 0 to 1 differ from the length of the entire curve?
The length of a curve from 0 to 1 refers to the distance between the starting point (0) and the endpoint (1) on the curve. This is a specific portion of the entire curve, which may have a different length. The length of the entire curve would be calculated by finding the distance between all points on the curve, from start to finish.
