Find the Limit of a Sequence: Tips & Techniques
In summary, the conversation discusses a sequence from a picture and how to demonstrate that it has a limit. The individual struggles with approaching exercises like this and asks for advice. A joke is made about being careful, and the conversation then goes into discussing the sequence and how it does not converge. The individual also mentions trying to calculate the difference between consecutive terms and the possibility of the limit being "X", but it is determined that the sequence does not have a limit.
Vali
48
I have the sequence from the picture and I have to demonstrate that this sequence has a limit.
I always get stuck at this kind of exercises.How to approach an exercise like this?
Mathematics news on Phys.org
...by walking on tip-toe :)
Sorry for my bad English, if that's what you mean..
No. Just a joke...
"walking on tip-toe" means "very carefully"!
Hi Vali.
Unless I’ve missed something, I make it that the sequence does not converge.
Observe that
$$x_n^2=\left(x_{n-1}+\frac1{x_{n-1}}\right)^2=x_{n-1}^2+2+\frac1{x_{n-1}^2}>x_{n-1}^2+2.$$
Thus:
$$x_n^2>x_{n-1}^2+2>x_{n-2}^2+4>\cdots>x_0^2+2n>2n.$$
Thus $x_n>\sqrt{2n}\to\infty$ as $n\to\infty$ $\implies$ $x_n$ also $\to\infty$ as $n\to\infty$.
Thank you for the answer.
I tried to calculate x_(n+1) - x_(n) which is 1/x_(n) which is positive so x_(n) increases.Then, I assumed that x_(n)>0 and demonstrate that x_(n+1) > 0 but x_(n+1)=x_(n)+1/x_(n) so x_(n+1)>0 and now I don't know how to continue.
Olinguito gave you the complete answer.
As an aside, not for pre-calculus, I notice that the difference between any 2 consecutive terms is a convergent of [a; a, a. ...] where a = x_0 . Is this correct?
I would start by assuming that a limit exists and determining what that limit must be. Calling the limit "X" and taking the limit on both sides of \(\displaystyle x_{n+1}= x+\frac{1}{x_n} \) we get \(\displaystyle A= A+ \frac{1}{A}\). That reduces to \(\displaystyle \frac{1}{A}= 0\) which is not true for any A! As Olinguito said, this sequence does not converge.
FAQ: Find the Limit of a Sequence: Tips & Techniques
What is a sequence?
A sequence is a list of numbers that follow a specific pattern or rule. Each number in the sequence is called a term.
What is the limit of a sequence?
The limit of a sequence is the value that the terms in the sequence approach as the index (or position) of the terms increases without bound.
How do I find the limit of a sequence?
To find the limit of a sequence, you can use various techniques such as the squeeze theorem, the ratio test, or the root test. You can also use algebraic manipulation or graphing to determine the limit.
What are some tips for finding the limit of a sequence?
Some tips for finding the limit of a sequence include identifying the type of sequence (arithmetic, geometric, etc.), looking for patterns or rules, and using known limit properties such as the sum, difference, or product rule.
Why is finding the limit of a sequence important?
Finding the limit of a sequence is important in many areas of mathematics, such as calculus, where it is used to determine the convergence or divergence of a series. It also has applications in physics, engineering, and other fields where continuous change is studied.
