Find the limit of the this equation
  • Thread starter shwanky
  • Tags
    Limit
In summary, the conversation is about evaluating the limit of a given function, which leads to a discussion of using conjugates and trigonometric identities. The person initially gets stuck but then figures out how to solve the problem and determines that the limit approaches negative infinity as t approaches 1 from the right.
shwanky
43
Evaluate the limit if it exists.
[tex]lim_{x\to2} \frac{\sqrt{x-6}-2}{\sqrt{x-3}-1}[/tex]
Completely lost, I've tried, finding the conjugate of both the numerator or denominator and I'm unable to find a solution.
Are you sure that is the problem? AT x= 2, the fraction is
[tex]\frac{2i- 2}{i- 1}= 2[/tex]
Nothing hard about that!
Perhaps you meant
[tex]\frac{\sqrt{6- x}- 2}{\sqrt{3- x}-1}[/itex]
which is "0/0" when x= 2.
Use the "conjugates" as you mention- multiply both numerator and denominator by [itex](\sqrt{x-6}+2)(\sqrt{x-3}+1)[/itex]. You will get x2-4 in the numerator and x-2 in the denominator and can cancel.
ok, here's another one I don't understand.
[tex]lim_{t \to 0} \frac{x+1}{xsin(\Pi x)}[/tex]
[tex]lim_{t \to 0} \frac{x+1}{xsin(\Pi x)}(\frac{x-1}{x-1})[/tex]
[tex]lim_{t \to 0} \frac{(x^2-1)}{(x^2-1)sin(\Pi x)}[/tex]
[tex]lim_{t \to 0} \frac{(1)}{sin(\Pi x)}[/tex]
At this point I get stuck... the [tex]sin(\Pi x)[/tex] is still 0. I tried using some of the trig identities, that I actually remembered, and got this.
[tex]lim_{t \to 0} \frac{(sin^2(\Pi x) + cos^2(\Pi x)}{sin(\Pi x)}[/tex]
Now I thought if I could get I could get the numerator in terms of sine, I could simple divide into it, but I'm not sure if this would work :-/... any suggestions?
is it possible for me to do
[tex]lim_{t \to 0} \frac{(1)}{csc(\Pi x)}[/tex]
[tex]lim_{t \to 0} sin(\Pi x)[/tex]
mmm never mind. there was a problem in my solution. [tex]xsin(\Pi x)(x-1)[/tex] does not equal [tex](x2-1)sin(\Pi x)[/tex]... I will try again...
ok, I think I got it.
[tex]lim_{t \to 1} \frac{x+1}{xsin(\Pi x)}[/tex]
[tex]lim_{t \to 1} \frac{x+1}{xsin(\Pi x)}(\frac{csc(\Pi x)}{csc(\Pi x)})[/tex]
[tex]lim_{t \to 1} \frac{(x+1)(csc(\Pi x)}{x}[/tex]
[tex]lim_{t \to 1} csc(\Pi x) + \frac{(csc(\Pi x)}{x}[/tex]
[tex]lim_{t \to 1} csc(\Pi * 1) + \frac{(csc(\Pi *1)}{1}[/tex]
[tex]lim_{t \to 1} csc(\Pi) + (csc(\Pi)[/tex]
[tex]lim_{t \to 1} 2csc(\Pi)[/tex]
[tex]lim_{t \to 1+} 2csc(\Pi) = +\infty[/tex]
[tex]lim_{t \to 1-} 2csc(\Pi) = -\infty[/tex]
Sorry, the limit is t->1+ not t->0...
ok, now if I take the left hand limit and right hand limit, the right hand limit approaches infinity while the left hand appraches negative infinity?
Does it bother you at all that you are taking the limit as t-> 1 but there is no t in the formula?! (Mathematics requires precision- be careful what you write!)
Perhaps you meant
[tex]lim_{t \to 1^+} \frac{t+1}{tsin(\Pi t)}[/tex]
I don't see difficulty with that. The denominator is continuous and at t= 1 is [itex](1)sin(\pi)= 0[/itex] but the numerator does NOT go to 0. What does that tell you?
(Don't capitalize "Pi"- you want \pi: [itex]\pi[/itex].)
o_O... I am such a dork...
[tex]\lim_{t \to 1^+} \frac{t+1}{tsin(\pi t)} = -\infty [/tex] as [tex]t \to 1^+[/tex]
FAQ: Find the limit of the this equation
What is the concept of finding the limit of an equation?
The limit of an equation is the value that a function approaches as the input values get closer and closer to a certain point. It is used to understand the behavior of a function near a particular point.
How do you find the limit of an equation algebraically?
To find the limit of an equation algebraically, you can use techniques such as factoring, rationalization, and substitution. These methods help to simplify the expression and determine the value that the function approaches.
Can the limit of an equation be undefined?
Yes, the limit of an equation can be undefined if the function has a vertical asymptote or a point of discontinuity at the particular value being evaluated. In this case, the function does not approach a specific value as the input values get closer to the point.
Is there a difference between one-sided and two-sided limits?
Yes, there is a difference between one-sided and two-sided limits. A one-sided limit only considers the input values approaching the point from one direction, either from the left or the right. A two-sided limit considers the input values approaching the point from both directions.
What role does the graph of a function play in finding the limit?
The graph of a function can provide visual aid in understanding and determining the limit. By analyzing the behavior of the function near the point being evaluated, you can make a conjecture about the limit. However, it is important to note that a graph alone is not sufficient to find the limit, and algebraic techniques should also be used.
