Find the magnetic field in vacuum given an electric field
In summary, the conversation is about solving Maxwell's equations to find the magnetic field when given an electric field in vacuum. The electric field in question has a z component only and blows up at t=0. There is a discrepancy in dimensions in the given expression for the electric field. There is also some confusion about F(r), which is an integration constant to satisfy the boundary conditions of the magnetic field, and whether or not the equations should be posted publicly.
Elijah1234
Given an electric field in vacuum:
Find the magnetic field under condition that |B| -> 0 as t -> infinity.
I clearly have to use Maxwells equations to obtain the electric field here. Our equation for B has to satisfy them. More specifically Faraday's law and Ampere's law I think are most important here.
I am going to use Faraday's law, take the - curl of the electric field and integrate it w.r.t to time. Curl of E will be E_0/(c*t^2) ( 1, 0 , 0).
Integrate this with a minus sing w.r.t to time, and get E_0/(c*t)(1,0,0) + F(r), where F(r) is a function of r we need to find.
Now, we also need B to satisfy Ampere's law and vanish at infinite time. But this field has zero curl, unless F(r) is non-zero, but how can F(r) be nonzero if B has to vanish at infinity? And even if it was non-zero, I have no idea how it could satisfy Ampere's law, as dE/dt if a function of t, but curl of B is not. And I can not find any other form of B except E_0/(c*t)(1,0,0) + F(r) as nothing else seems to satisfy Faraday's law. I am entirely confused.
E_0/(c*t)(1,0,0) goes to zero for infinite time, so F(r) can do that as well.
Well, your B has to depend on time as well.
But if F(r) is to go to zero for infinite time, then it appears that F(r) would depend on t. Then wouldn't Faraday's law no longer be satisfied for finite t?
I can't find a solution to this problem.
Wait, what exactly do you call F(r)? It is introduced outside an equation. Where is the corresponding Maxwell equation?
F(r) is just an integration constant. I took an integral w.r.t to time, so I can add on any function of position to it, as long as b.c. are satisfied.
So where do you solve the Maxwell equations now?
What do you mean?
You have an electric field, you want to find the magnetic field. You know that both together have to satisfy the Maxwell equations - that is the only connection between them (Faraday's law and Ampere's law are part of the Maxwell equations). You have to find a magnetic field such that electric plus magnetic field satisfy the equations. I don't understand how you could start at all without understanding that.
I am trying to solve Maxwells equations. Maxwells equations are differential equations, so there is no one specific solution to them, fields are gauge invariant and what determines the solutions are boundary conditions. So I integrate the maxwells equations to find the solution as one solves a differential equation by integrating. F(r) is just an integration constant to satisfy the boundary conditions of the B field. Sorry if I want clear on that, but I hope now it will be more obvious what I am doing.
Okay, where are those equations, before or after integration? That's what I am missing here.
I used one of the Maxwell equations relating B to E. It's an ODE since the E field has a z component only. Blew up at t=0 though ...
BTW is this in cgs or ? or are the units inconsistent in the given expression for E?
Note that the E field given also blows up for non zero y as t goes to zero. So there must be a condition on time that is implicitly assumed in the question (at least t>0)
Agreed. Did you get an answer? Would like to compare, in private to avoid breaking pf's rules ...
... oh, and what about the dimensions discrepancy? Any comment?
Well, it would be much better if you posted here your steps, so that we (me or someone else) could check the steps.
As for the units, there is something fishy from the very beginning as the E field given does not even have the units of an electric field. Is this a problem from a textbook or was it given by the prof?
As they said in the old TV series The Prisoner: "That would be telling"! We are not supposed to provide OP's with turnkey answers.
I agree, it's weird. But I've run into weird stuff with physicists using the cgs system (where there is no electric unit of any kind). Hard to believe my own physics intro course used cgs; thank goodness that seems to be waning or has waned.
By choosing appropriate units for the constant ##E_0##, the overall units for the electric field will be correct for whatever system of units you have chosen to work in. So I don't see any problem with units. I think the OP's argument is correct for showing that there is no solution to this problem. To recap the OP's reasoning:
(1) First note that ##\vec{\nabla} \times \vec{E} =\large \frac{E_0}{ct^2}## ##(1, 0, 0)##.
(2) Integrating the vacuum Maxwell equation ##\vec{\nabla} \times \vec{E} = - \large \frac{\partial \vec{B}}{\partial t}## with respect to ##t## leads to ##\vec{B} = \large \frac{E_0}{ct}## ##(1, 0, 0) + \vec{f}(\vec{r})## where ##\vec{f}(\vec{r})## is an arbitrary vector function of position which is independent of time. ##\vec{f}(\vec{r})## is the "constant of integration" when integrating with respect to ##t##.
(3) However, the boundary condition ##B \rightarrow 0## as ##t \rightarrow \infty## requires ##\vec{f}(\vec{r}) = \vec{0}## . So, ##\vec{B} = \large \frac{E_0}{ct}## ##(1, 0, 0)##.
(4) It is impossible for ##\vec{B} = \large \frac{E_0}{ct}## ##(1, 0, 0)## to satisfy the vacuum Maxwell equation ##\vec{\nabla} \times \vec{B} = \large \frac{1}{c^2} \frac{\partial \vec{E}}{\partial t}## since the left hand side is identically zero while the right hand side is nonzero.
I think this argument is valid. Or am I overlooking something?
Likes mfb
Certainly misleading to call the constant E-something, don't you think? Let me restate E = k(0,0,y/t2). Then,
in your point 4, why do you say the left-hand side is identically zero? ∇ x E = - dEz/dy = -k/t2 ≠ 0?
Otherwise my derivation is same as yours I believe.
Yes, a different symbol for the constant would be better.
Then,
In point 4 we are looking at x B rather than x E. The result for x E was given in point 1 and used in point 2.
Oops, I missed that. Right.
I suppose the problem was conjured up from ∇ x E = - B/∂t alone, without regard to physical realizability. Thanks.
Related to Find the magnetic field in vacuum given an electric field
1. What is the relationship between electric and magnetic fields in vacuum?
The relationship between electric and magnetic fields in vacuum is described by Maxwell's equations. These equations state that a changing electric field will generate a magnetic field, and a changing magnetic field will generate an electric field. In vacuum, the two fields are perpendicular to each other and both are necessary for electromagnetic waves to propagate.
2. How do you calculate the magnetic field in vacuum given an electric field?
To calculate the magnetic field in vacuum given an electric field, you can use the equation B = μ0ε0E, where B is the magnetic field, μ0 is the permeability of free space, ε0 is the permittivity of free space, and E is the electric field. This equation is derived from Maxwell's equations and is valid for vacuum or free space.
3. What are the units for the magnetic field in vacuum?
The units for the magnetic field in vacuum are tesla (T) or gauss (G). These units represent the strength of the magnetic field, with 1 T equal to 10,000 G. In the equation B = μ0ε0E, the units for B are determined by the units for μ0 and ε0, which are respectively measured in henry per meter (H/m) and farad per meter (F/m).
4. Can the magnetic field in vacuum exist without an electric field?
No, the magnetic field in vacuum cannot exist without an electric field. As stated in Maxwell's equations, a changing electric field is necessary for the existence of a magnetic field. In vacuum, electromagnetic waves travel through the oscillation of both electric and magnetic fields, and the two fields are interdependent on each other.
5. How does the strength of the electric field affect the strength of the magnetic field in vacuum?
The strength of the electric field directly affects the strength of the magnetic field in vacuum. As shown in the equation B = μ0ε0E, the magnetic field is directly proportional to the electric field. This means that an increase in the electric field will result in a proportional increase in the magnetic field. Similarly, a decrease in the electric field will result in a proportional decrease in the magnetic field.
