Find the magnitude of the current density
In summary, the magnitude of the current density, calculated using the equation J = nev, for a beam containing 3.95×10^8 doubly charged positive ions per cubic centimeter moving north with a speed of 1.64×10^5 m/s is 20.72 A/m^2. It is important to check the units of all factors to avoid mixing different measures and rounding should only be done at the end for presentation of results.
Sho Kano
372
A beam contains 3.95×108 doubly charged positive ions per cubic centimeter, all of which are moving north with a speed of 1.64×105 m/s. What is the magnitude of the current density?
J = nev
n = electron density
e = electron charge
v = drift velocity
J = nev
J = 3.95e8 * 1.6e-19 * 2 * 1.64e5
J = 2.07e-5 A/m^2
I'm getting marked wrong for this?
Check the units of all the factors to make sure you're not mixing different measures.
It works out,
n = [m^-3]
e = [C]
v = [m/s]
n*e*v = C/s*m^2 = A/m^2
OH WAIT,
n = [cm^-3]
n = 3.95e14 m^-3?
How many cubic centimeters in a cubic meter?
[itex]3.95e8\frac { 1 }{ cm\^ 3 } *\frac { 100cm }{ m } *\frac { 100cm }{ m } *\frac { 100cm }{ m } [/itex]
So then, what's the charge density in coulombs per cubic meter?
2*1.6e-19 / 3.95e14 m^-3 = 8.101e-34
8.101e-34 * 1.63e5 = 1.32e-28 ?
No. Why did you divide by the number density? That makes the m^-3 into m^3 in the numerator.
Yea my bad, I'm just not into it today. So it's,
3.2e-19 * 3.95e14 = 1.26e-4
1.26e-4*1.64e5 = 20.72
That's better.
You need to add units to your result. Also, you should avoid rounding intermediate values during calculations as that introduces rounding and truncation errors that can creep into your significant figures. Only round at the end for presentation of results.
FAQ: Find the magnitude of the current density
What is current density?
Current density is a measure of the flow of electric current through a specific area. It is represented by the symbol J and is measured in units of amperes per square meter (A/m^2).
How do you calculate the magnitude of current density?
The magnitude of current density can be calculated by dividing the magnitude of the current (I) by the cross-sectional area (A) through which the current is flowing. This can be expressed as J = I/A.
What factors affect the magnitude of current density?
The magnitude of current density is affected by the magnitude of the current, the cross-sectional area through which the current is flowing, and the material through which the current is passing. The type of material and its resistivity can greatly impact the magnitude of current density.
What are some practical applications of calculating current density?
Current density calculations are used in a variety of applications, such as designing electrical circuits, determining the heating effects of current flow, and analyzing the performance of electronic devices.
How is current density related to other electrical properties?
Current density is related to other electrical properties such as electric field, electric potential, and resistance. It is also related to the flow of charge, as it represents the amount of charge passing through a specific area in a given amount of time.
